how do u get the wastegate to dump to atmosphere??
Old Jan 18, 2002 | 12:46 AM
i know its a stupid question.
mike
87 t2
Old Jan 18, 2002 | 12:49 AM
rx7_turbo2's Avatar
Professor D.P
Do you mean the blow off valve?
If you mean the wastegate then you need to purchase an external wastegate.
Old Jan 18, 2002 | 12:52 AM
is it worth i or even possible to use a external wastegate with a stock turbine?
Old Jan 18, 2002 | 03:48 AM
fcturbo2's Avatar
unless you are going to use aftermarket turbos then you have to use external wastegate. No its not possible to use ext. wastegate with a stocker. But you can port your stock wastegate to eliviate boost creep.
Old Jan 18, 2002 | 03:57 AM
Node's Avatar
Old Jan 18, 2002 | 08:27 AM
4cefed7's Avatar
My TO4E was vented into the atmosphere.it is the loudest damn noise you will ever hear.
When using an external wastgate just dont route the wastegate pipe back into the exhaust, you then are dumping it into atmosphere
Old Jan 18, 2002 | 08:32 AM
4cefed7's Avatar
I guess it could be done but its almost pointless. just weld the internal gate closed ang have someone modify the factory manifold to accept an external gate(you would have to have a pipe welded to the manifold to mount the gate) you also might be able to buy an aftermarket manifold(HKS etc) and modify the housing to accept a stock turbo.
But again if you are running a 89+ turbo this would probably do very little for you except lighten you wallet.
Old Jan 18, 2002 | 12:04 PM
B430's Avatar
why would you want to do this?
Old Jan 18, 2002 | 12:40 PM
AE Turbo's Avatar
Speed from skill
Wouldn't an external wastegate make a cool noise? :p
Old Jan 18, 2002 | 01:06 PM
cymfc3s's Avatar
I Raise Chickens
Because it sounds like some just unleashed holy hell from underneath your car when you get on it. (Chicks dig it too) =]
Old Jan 18, 2002 | 08:56 PM
fcturbo2's Avatar
Originally posted by Node
NODE dont you know that most aftermarket turbos use external wastegates???
Old Jan 18, 2002 | 08:57 PM
fcturbo2's Avatar
Chris-- will the wastegate i got from you make a loud noise with my t04b set-up?
Old Jan 18, 2002 | 09:36 PM
Felix Wankel's Avatar
Super Newbie
Any wastegate plumbed into the atmosphere will be loud, as it basically becomes a straight pipe exhaust
Old Jan 18, 2002 | 11:08 PM
fcturbo2's Avatar
Ple enlighten me on this question.
Say you have a 7psi wastegate. Does this mean that it will open up when it sees 7 psi of boost??..WOuld it be better if you have a higher psi wastegate, say a 10 or something??...Because i heard of people changing the springs from a 7psi and putting a stiffer spring..Anyone know how??
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
subeone
Sep 24, 2015 09:58 PM
