Where is the FCD Located?
Old Sep 11, 2005 | 04:23 PM
tIIsleeper's Avatar
pp
I am getting the rtek1.7 and I was wondering where the fcd is thats in my car now is located and do I put the stock one back in because of the rtek or do I leave the Racing beat one in?
Old Sep 11, 2005 | 05:09 PM
First gen man's Avatar
yessir
it should be located right next to the MAP sensor
Old Sep 11, 2005 | 05:19 PM
TII-aholic's Avatar
Busa dude
no...its plugged into the pressure sensor and should be removed when using the rtek chip.
Old Sep 11, 2005 | 06:00 PM
RidicilousRx7's Avatar
1993 Mazda RX7 R1
so when i plug my rtek 1.7 ecu i should take out the fcd?
Old Sep 11, 2005 | 06:29 PM
MattB's Avatar
MattB
yes...it has one built in...
Old Sep 12, 2005 | 01:59 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by TII-aholic
no...its plugged into the pressure sensor...
Same thing. MAP = manifold absolute pressure sensor, it's full and correct name.
Old Sep 12, 2005 | 02:02 AM
trochoid's Avatar
Old Fart Young at Heart
Since you are unsure of the fcd location, are you sure you have one? It is not a stock item.
Old Sep 12, 2005 | 01:13 PM
tIIsleeper's Avatar
pp
I have one. The stocker is in the glove compartment and there is no fuel cut
Old Sep 13, 2005 | 02:30 AM
There is no stock FCD!
Are you sure that's what it is? Normally they're either plugged into the MAP sensor plug or wired in directly at the ECU. The glove box is an odd location...
Old Sep 13, 2005 | 02:55 AM
SonicRaT's Avatar
Super Raterhater
Unless he means the stock MAP sensor, and somebody just plugged the FCD in and took out the pressure sensor?
Possible? Maybe..
Old Sep 13, 2005 | 10:37 AM
tIIsleeper's Avatar
pp
What does the stock piece look like? The one that is in the glove compartment is not hooked up and it looks just like the RB one. Two connectors, small square, black box.
Old Sep 13, 2005 | 10:40 AM
tIIsleeper's Avatar
pp
What does the stock one look like? The one thats not hooked up in the glove box looks like the RB one. Two connectors, small square black box.
Old Sep 13, 2005 | 10:41 AM
tIIsleeper's Avatar
pp
Old Sep 13, 2005 | 10:47 AM
SonicRaT's Avatar
Super Raterhater
Wow, triple play! LOL, the stock pressure sensor has a little vacuum nipple on the bottom, and a metal rod coming out of the top, and it'll have a label that says N33x on it or something similar. It sounds like you've possibily got two FCD'S? A FCD is just a box (some have labels, some don't), with a harness coming out that has two connectors on it and connects inbetween the stock pressure sensor (bolted to the passanger strut tower), and the stock engine harness.
Old Sep 13, 2005 | 11:00 AM
tIIsleeper's Avatar
pp
I didnt mean to post three times.
Old Sep 13, 2005 | 11:11 AM
SonicRaT's Avatar
Super Raterhater
yeah, forum gets whacky sometimes. Pop your hood and peak at your pressure sensor (on the passanger strut tower) See if you can trace the wiring back and find another box located near it. Is there any writing on the box in your glovebox? (wow, lots of box)
Old Sep 13, 2005 | 11:15 AM
red87tll's Avatar
needs a cheaper hobby
its on the passanger shock tower under the hood, its about 2 inch by 2 inches and its black. if it has the harnedd from the car plugged into it directly then you are not running a FCD. if there is a box spliced into it then chances are you have a FCD.
Old Sep 14, 2005 | 12:42 AM
Which part of "there is no stock FCD" did you not understand?
ncds_fc
19
Sep 15, 2015 12:03 AM
