Problems after clutch install - wont go into gear!
Old Sep 11, 2005 | 10:44 AM
Spoolerr's Avatar
I dropped the trans last night and replaced the clutch, tightened everything up, it was a new dynapak clutch. I put the car all back together and now it wont even go into gear while running. I bled the clutch system and the clutch looked right, is it possible i messed up the to bearing when i dropped the trans down?
any possible causes before i go take the trans out again?
I have an S4 TII
arrgg!
thanks
brandon
Old Sep 11, 2005 | 10:49 AM
Spoolerr's Avatar
Is there a difference between S4 and S5 turbo clutches? I have an S5 engine, and i am realizing its an s4clutch...
hmmm
Old Sep 11, 2005 | 11:18 AM
Impreza2RX7's Avatar
did you mess the pilot bearing up and is the clutch fork moving when you depress the clutch? There is no difference is series 4 and 5 clutchs.
Old Sep 11, 2005 | 12:31 PM
Spoolerr's Avatar
the pilot bearing shouldnt have anything to do with it i wouldnt think, altho,it does seem a little noisy.
It just wont allow me into gear, the for moves, its been bled, i dont know what else to do.
brandon
Old Sep 11, 2005 | 12:32 PM
aznpoopy's Avatar
strike up the paean
start simple... jack up the car and have someone step on the clutch pedal. see if the slave cylinder is extending the piston, etc. etc.
Old Sep 11, 2005 | 01:58 PM
turbo80cid's Avatar
I think this has happened to people that put the clutch plate in backwards.
Old Sep 11, 2005 | 02:17 PM
88t2romad's Avatar
(_8(|)
Doh, guess it helps to read the post better..
Old Sep 11, 2005 | 02:19 PM
Wankel7's Avatar
Haven't we ALL heard this
Originally Posted by 88t2romad
did the clutch hydraulic system get bled?
Yes
Old Sep 11, 2005 | 02:21 PM
Spoolerr's Avatar
Yes it got bled, jesus i hope i didnt put the disk in backwards but it could be a possibility. I was really tired (about 2am trying to get the car done for work today @ 10)
I guess i will pull the car back apart and hopefully the disk is just in wrong. any other suggestions would be greatly appreciated
thanks
brandon
Old Sep 11, 2005 | 03:00 PM
easymmkay240sx's Avatar
you say it's noisier? my friend's pilot bearing went(was really noisy before it went) I think the problem was not greasing it properly before reinstalling. the bearings came out and ruined the flywheel and such....he also couldn't put it into gear.
Old Sep 11, 2005 | 03:01 PM
Spoolerr's Avatar
really.. hm
i will check it out
thanks
brandon
Old Sep 11, 2005 | 07:52 PM
Spoolerr's Avatar
Yup, the pilot bearing is shot, i will replace it and report back
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
thatfbtho
13
Aug 29, 2015 10:51 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
