Do I HAve To Use A Block Off Plate?
Old Jan 16, 2002 | 11:48 AM
rico05's Avatar
WTB S5 N/A FC
Do I HAve To Use A Block Off Plate When Removing Air Pump?
I want to remove my airpump. I am wiring my 5th and 6th ports open, and i gutted all my cats. Do I really need to block it off? 1991 N/A
Old Jan 16, 2002 | 12:26 PM
rico05's Avatar
WTB S5 N/A FC
bump
Old Jan 16, 2002 | 12:33 PM
cymfc3s's Avatar
I Raise Chickens
only if you remove your air control valve.
Old Jan 16, 2002 | 12:53 PM
SpeedRacer's Avatar
Formula Mazda Driver
The only thing you need to block after removing the airpump is the hole in the ACV where the airpump outlet tube went. I just used a cork to block that hole. Also the hole on intake elbow that went the airpump can be blocked off with a cork. Pretty high-tech huh?
