Bad Smell When Running Hard
Old Jan 15, 2002 | 10:12 PM
mightyslash's Avatar
Will Work for Ferrari
Angry Bad Smell When Running Hard
If I rolled down the windows and ran the car hard, I'd smell something bad. It's hard to describe the smell but it seemed to me that something's burning.
Old Jan 15, 2002 | 10:45 PM
Johnny's Avatar
OG
hopefully your clutch
Old Jan 15, 2002 | 10:48 PM
GsrSol's Avatar
Z06 powered FD
Got any exhaust leaks?
Old Jan 15, 2002 | 10:49 PM
I know my clutch is wearing down (needs to be replaced), but I'm not sure about the exhaust leak. How do I know if there's exhaust leak?
Old Jan 15, 2002 | 11:09 PM
atihun's Avatar
Smelled like burning oil?
How many miles do you have on your car?
If its oil, it is either:
-rear main seal leaking onto exhaust
-secondary turbo leaking onto exhaust
Old Jan 15, 2002 | 11:14 PM
Maybe it's the oil, not sure. 141k miles on my car. Oh yeah, I'd only smell it after second turbo kicks in.
Old Jan 15, 2002 | 11:49 PM
atihun's Avatar
Check under your car; look at the secondary turbo and see if there is oil droplets at the bottom of the housing, and also see if there is oil burnt onto the main catalytic converter and back.
How much oil do you see on the ground after driving?
Old Jan 15, 2002 | 11:52 PM
My mechanic just did the oil seal for the turbos, so there should be no leaks.
Old Jan 15, 2002 | 11:59 PM
2-Rotor's Avatar
Garaged
Is it a rotten egg smell??? I would check to see if you main cat is glowing try looking at night.
Old Jan 16, 2002 | 12:00 AM
MAESTRUL's Avatar
How about your brakes??
My .02 cents.
DAN
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Wolf_
Aug 11, 2015 04:23 PM
