NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
need help in south jersey
Old Aug 20, 2005 | 10:26 AM
redlineracer's Avatar
Would there be anyone in the south jersey area that could come down and help me out with my seven.
I have done the bareblock mod and throttle body mod.
I'm just having trouble keeping the car running.
It will start but then the idle jumpes. I adjusted the tps and still no progress i changed out the throttle body and now it wont stay on.
Please if anyone can come down I will gladly pay you.
Alex
Old Aug 20, 2005 | 10:32 AM
Bacon's Avatar
IRS 4 Life
bare block mod?
Where @ in Sj?
Is the idle hunting or jumping all over the place, have you adjusted your idel screw, did you hook up all connectors? is the map sensor hooked up?
Old Aug 20, 2005 | 10:35 AM
its hard to explan. i would really like it if you came down. I'm pretty close to sicklerville. I need to do this so i can register the car. I am the only person i know that works on these cars. So, I believe that with someone else with knowlege of these cars could be a great help.
Old Aug 20, 2005 | 04:39 PM
moehler's Avatar
If the car is driveable, take it to JPR imports in Blackwood NJ. Talk with Jim (856-227-1808).
Old Aug 20, 2005 | 09:15 PM
no it is not registered or insured. worse come to worse i'll have to get it towed.
Old Aug 20, 2005 | 11:12 PM
cmartinp28's Avatar
what is the bare block mod?
i have a feelign you left a vaccuum nipple unplugged
Old Aug 21, 2005 | 08:45 PM
No, bacon came down to give me a hand and got it working.
"Bocaon you rock."
If you ever need anything, anything at all give me a call.
Old Aug 21, 2005 | 09:25 PM
Bacon's Avatar
IRS 4 Life
Alex,
I still say your car is possessed, LOL I need go get BaconSportsRacing Stickers cut, LMAO
Basically his car had a hunting idle like the air bleed screw was way tight, But with all the AWS system removed and the idle speed control motor not there I couldn’t get it to hold a steady idle below 1200-1300 rpm The TPS was only happy with the idle a little out of perfect spec, And it would still idle fine for 20 min, then after revving it would drop and struggle to idle then jump right back to solid idle. Very weird
But glad we got it to hold a steady idle; it needs Jim to take a look @ it either way.
Super nice and clean setup, I was definitely impressed. Keep up the good work
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
izzolaw
Sep 28, 2015 06:03 AM
Matthew Diaz
Sep 18, 2015 03:37 AM
rafgonz
Sep 7, 2015 06:36 AM
