water line in the manifold
Old Jan 15, 2002 | 12:28 AM
eddierotary's Avatar
back with rotaries
question?
i found a water line coming from the front of the engine to the manifold on my gslse, what is that for? if a eliminate it i gain hp or trouble.
Old Jan 15, 2002 | 04:44 PM
FJ's Avatar
FJ
It's part of the fast idle system. That coolant line and another 6" line to the rear of the block warm up the Thermo Wax, which will release the fast idle cam once the engine is warm.
Some people remove the coolant lines, thermo wax and the 2nd secondary throttle valves (part of the same system) to reduce complexity and slightly improve the flow through the throttle body, but as you live in New York I suspect you would appreciate the fast idle function more than the limited improvements you gain by removing it. I know I do.
-John.
Old Jan 19, 2002 | 01:39 AM
back with rotaries
well thanks i didn't know. i need the fast idle for the winter
FD7KiD
15
Feb 26, 2021 10:12 PM
rotor_veux
Aug 31, 2015 07:49 PM
FD7KiD
Aug 17, 2015 11:50 PM
