Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Updated track times and paint job...
Old Aug 18, 2005 | 06:49 AM
vxturboxv's Avatar
Well I hit the 11's! 11.98 at 115 1.68 60' on the nitto 555r's!
Slapped on a new paint job as well. Went with satin black.... The car is down now, swapping over to the factory buick ECM and an LS1 MAF setup. Should be alot more streetable than the old DFI 6.0 unit. I was avg. 15-18 mpg. Should avg 22mpg+ with the new lean cruise chip!! If I install a LU converter 28mpg+. Not bad MPG for an 11 sec street car...
Hoping for low 11's at 120+ with the new te-61 turbo and GTQ exhaust wheel, and a nicely tuned alky chip for the factory ECU!
I was thinking of putting louvers on it? Anyone have a good pic of a 2nd gen with louvers? I'm go'n mad max style...
Attached Thumbnails Updated track times and paint job...-te62small.jpg   Updated track times and paint job...-daypic2.jpg   Updated track times and paint job...-daypic4.jpg   Updated track times and paint job...-daypic5.jpg
Old Aug 23, 2005 | 10:51 PM
20B Junkie's Avatar
Congrats man....I always contemplate getting a Buick GN someday lol And gas mileage is nice for a car that fast. Are you running an auto tranny by the way?
Old Aug 25, 2005 | 03:58 AM
Nihilanthic's Avatar
moon ******
Old Aug 25, 2005 | 02:28 PM
vxturboxv's Avatar
Yup, running the factory buick 200-4r auto. trans. With WAY to large of a converter 3400 9" art carr non LU unit. I think that huge converter is the only reason the factory NA rx-7 rear diff has held up. Going with an manual would be nice for roll races, but it would destroy the rear end if you tried to drag race it!
Old Aug 25, 2005 | 10:03 PM
andrewb70's Avatar
What paint did you use on the exterior?
Andrew
Old Aug 26, 2005 | 08:55 AM
vxturboxv's Avatar
Andrew
Just a standard gloss black with a flattener in it.
Old Aug 28, 2005 | 04:57 PM
TOUGHGUY's Avatar
Got some screws loose!
That looks awesome in a MAD MAX sorta way. Too bad the scoop has to be so big but frankly, the rear end is what most people will see the most of anyways right? BTW, are those 555s hooking strong with a 3400 stall or does it do the wiggle before it digs in?
Sean
Old Aug 29, 2005 | 02:13 PM
vxturboxv's Avatar
Sean
The car pretty much dead hooks at the track I was amazed. I'm to much of a tight *** to do a big burn out before mylaunchI usually just spin the tires a little to get thedirtoff. But I was pulling constant 1.6-1.7 60 ft times. Launching at 6lbs of boost. If I beef up the rear brakes I think I could launch at 10+ lbs of boost and net some low 1.6 or 1.5 60 foots. On the other hand it spins all over the place on the street. Rolling at 45 if I stop the gas it flashes the converter and lights'm up! It's fun!
Old Apr 4, 2006 | 01:37 PM
vxturboxv's Avatar
New track times.
Getting the car dialed in with new trans. Managed a 120 trap last week! Unfortunatly I've lost my spool up down low and can't build boost off the foot brake anymore. Oh well lots of street roll racing until I figure it out. Got some evil top end now! 27lbs of boost on 91 octane and methanol injection. Zero knock, it's awesome!
Old Apr 4, 2006 | 04:16 PM
jacobcartmill's Avatar
just dont care.
hey i trapped 116, i guess this proves i could hit 11's with a good 60ft
(i had a 2.2 60ft on my 12.8 run)
edit: i'm guessing you have quite a bit more tq than me, but i'm hoping i could still hit an 11.9x pass
Old Apr 4, 2006 | 05:34 PM
andrewb70's Avatar
If you ever get real tires...hint...hint...
Andrew
Old Apr 5, 2006 | 01:44 AM
vxturboxv's Avatar
with 360 RWHP you coudl run low 11's all day with some tires... Got any pics of your swap? I'd like to check it out.
Old Apr 7, 2006 | 06:58 AM
TOUGHGUY's Avatar
A 120 trap but only 2.11 60ft! You know there's a second to be had at the big end if you tried some drag slicks!
And don't be such a tight ***, light them up good in the burn box. Oh and keep the front wheels pointing forward when you feel them lifting.
Sean
Old Apr 7, 2006 | 11:58 AM
vxturboxv's Avatar
Slicks would also cause a broken axle. I don't even have the tII rearend. So I've been pushing it this whole time.
The cars biggest problem isn't traction it's gearing. The buick motor redlines at 5300. 410 gears a 200r4 trans and 5300 rpm don't go together well. I need at lot less gear. I'm in OD right after half track. Theres a good second to be had with the right gearing. And to do that I need to cut out the back of the car and install ladder bars and a soilid rear. Then i'll add slicks as well. Problem is, thats expensive!
Thanks 4 the input though!
Old Sep 28, 2006 | 03:09 AM
vxturboxv's Avatar
Getting faster!
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
