Power FC Adjust timing???
Old Aug 17, 2005 | 07:20 PM
westcoasttuner's Avatar
Question Adjust timing???
I just starting to tune with my power FC and have no clue what I am doing...with that said I have spoken with a shop that does pro tuning and they walked me thru uping my fuel to where I am now @ 11:1 AFR at full boost. But I am still concerned about my timing...under full boost my L timing is @ 21 degrees and I belive I should be @ 12...can I easily adjust this....PLEASE HELP, by the way my T timing is at 8-9 under full boost.
Old Aug 17, 2005 | 08:43 PM
cewrx7r1's Avatar
Eye In The Sky
Boost pressure is only a small part of determining timing.
List all of your intake, IC, turbo, porting, and exhaust mods.
Only the mods that affect air flow through the engine.
Old Aug 18, 2005 | 02:38 PM
I have custom intakes (basicly piping w/cone HKS style filters), Greddy FMIC, stock TT, the motor has been street ported, monster down pipe, and 3" Apexi exhaust w/no cat...also running 15psi boost.
Old Aug 19, 2005 | 10:53 AM
any input??? going drifting this wkend and would really like to maybe adjust my timing...PLEASE
Old Aug 19, 2005 | 02:57 PM
TailHappy's Avatar
Addicted to Track
I doubt you'll get any responses on tuning for timing other than Chuck. Most people on here just leave the timing maps the way they came with the PFC, other than cleaning up the split and the few bad cells. How are you determining that your leading timing is 21? If you're looking at the peak hold, you would see timing that advanced if you ran up to redline. On the high boost rows, timing is around 10-ish until you get to about 6800rpm, where it increases again.
Anyway, if you're not a guru at tuning, timing is not something you want to start experimenting with on a rotary unless you have deep pockets...
So have you been drifting yet? I'm surprised you don't have a lot of wheel hop problems unless you've already redone the suspension.
Old Aug 20, 2005 | 01:56 PM
cewrx7r1's Avatar
Eye In The Sky
I PMed westcoasttuner some info.
Old Aug 22, 2005 | 08:37 PM
Thanks. ^
The car drifted VERY well actually, had alot of fun and showed up a few 240sx. I had double the HP most of the guys had at the event so that helped
Old Aug 23, 2005 | 07:53 AM
TailHappy's Avatar
Addicted to Track
Sounds fun! Did you do any suspension/diff changes to the car or just take it out there stock? I've toyed with some drifting at autocrosses but I have a lot to learn.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
incubuseva
14
Sep 3, 2015 12:37 PM
