Auto Swap (5 Speed Harness, 5 Speedometer Harness, etc...
Old Aug 14, 2005 | 12:37 AM
circusmagic's Avatar
Does anyone have pics of the 3 harness for an auto-5speed swap? Currently installed the 5 speed harness but realized that 2 of the connectors(white connector near the firewire which is the speedometer harness and the blue connector right after the white connector for the relay?) will not fasten together. I uncertain which direction I should head...1)swap out the auto speedometer harness and get a 5speed harness and 5 speedometer and also get the other harness(blue connector). Or 2) modify the 2 connectors(white and blue) and reuse the auto harness connectors to fit the connectors that are on the car...then i will have to figure out how i'm going to connect the 5speed pedal's starter and clutch switch connector...
Old Aug 14, 2005 | 10:11 AM
After reading more the the Mazda Manual, The question I have is...How did most of auto swaps handle the X-14(white connector) and X-05(blue connector) if you use a new Manual Harness? The connectors differ...did you remove the auto X-14 connector and X-05 connect and use a the Manual X-14 and X-05 connector? Or did you just buy a new X-14 and X-05 harness? If I purchase new X-14 and X-05 harness, will everything plug in or will I have another item that will not match to the manual X-14 and X-05 harness?
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
OrangeMax
Sep 4, 2015 10:42 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
