Microtech Cuts out in 1st gear
Old Aug 12, 2005 | 10:24 AM
gergrx7's Avatar
Boosting Again
As soon as i go above 3300(where i have secondaries set up at) car will lean out and buck like crazy. It hits like 15afr. This only happends in 1st and sometimes 2nd gear. Car runs good in 3rd gear and above, it is set up at 10.5AFR right now and climing as RPMs rise. I have the car setup in normal mode right now. What can i adjust so it will actually go in 1st gear so it wont cut out.
Old Aug 12, 2005 | 04:46 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
what's the primary/secondary size?
staging %?
etc...
Old Aug 12, 2005 | 07:12 PM
gergrx7's Avatar
Boosting Again
550/1600
95%
they come on at 3300
Old Aug 12, 2005 | 08:09 PM
what kind of fuel pump?
you might try bumping it all the way up to 99%
Old Aug 12, 2005 | 08:27 PM
gergrx7's Avatar
Boosting Again
walbo 255, im going to try to bump it up to 99% and see what that does tommorow
Old Aug 13, 2005 | 02:12 AM
if you can, try running it uber-rich right before it stages and see if that helps out a little.
Old Aug 15, 2005 | 05:08 PM
gergrx7's Avatar
Boosting Again
i finally got it figured out, since i was useing hand controller i didnt realize what i was doing with the 2,4 and 6psi maps and i was only concentraining on 8 and 10psi maps. I had to use hand controller because i am useing zietronix wideband and it uses a serial port. but the lower psi maps were set really rich and then 10psi maps were good. so i fixed it so its a nice smooth curved line and i have mo more hesitation. I also set stage to 99%
Old Aug 15, 2005 | 06:59 PM
cool beans
Shainiac
Jul 17, 2019 02:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
