Most HP on Power FC?
Old Aug 12, 2005 | 09:37 AM
LUPE's Avatar
Anyone know if anyone out there is making 500+ hp with the Power FC? I know Jason (rx7store) did like 501hp.
Anyone else make more?
Old Aug 12, 2005 | 09:49 AM
SPEED_NYC's Avatar
RX-Parts
ralph from xcessive is making close to 700hp with a power fc if i remember correctly, his screen name is xcessive on here or you can just check the rxtuner issue with the write up of his car with the old turbo set-up
Old Aug 12, 2005 | 10:04 AM
LUPE's Avatar
Hmm, I'm just reading alot lately about how the power fc can't handle higher horsepower.
Old Aug 12, 2005 | 10:15 AM
Zero R's Avatar
Just in time to die
Ralph is one of the higher ones. But he runs his ignition setup different as well.
Old Aug 12, 2005 | 10:41 AM
LUPE's Avatar
How differently may I ask you, sir?
Old Aug 12, 2005 | 11:38 AM
CyborgRyu's Avatar
Drift FC
SEARCH!
Old Aug 12, 2005 | 12:28 PM
LUPE's Avatar
Originally Posted by CyborgRyu
SEARCH!
Weak.
Old Aug 12, 2005 | 01:45 PM
Zero R's Avatar
Just in time to die
He runs no split, he has it wired so the coils all fire off the same signal I believe.
Old Aug 12, 2005 | 01:52 PM
FB II's Avatar
fire everything off the trailing
Old Aug 12, 2005 | 08:46 PM
ErnieT's Avatar
Living life 9 seconds at a time
Eric,
Your really better off going with something like a Tec 3, Microtech, or Motec if you want to run high boost. I like the Tec3 because the ignition and trigger wheel is so accurate, it doesn't matter how much boost you run as long as the tune is right.
Old Aug 12, 2005 | 09:11 PM
LUPE's Avatar
Well, Kan is coming to St.Louis next week so I'll have to deal with the pfc. Hopefully with vp c16, I can make some power.
Old Aug 13, 2005 | 07:35 AM
Monkey-FD3S's Avatar
The Apexi can handle high horsepower no problem.
This is a link with refence to an EVO but it shows that the PFC is fine for high HP; perhaps some of you just don't know how to map it correctly.
http://www.rcdevelopments.co.uk/
930Bhp / 673lb/ft - 1/4 MILE @10.25Secs
Old Aug 14, 2005 | 09:21 AM
ErnieT's Avatar
Im not going with what somebody says in a magazine or for another car application. For an RX7 and a 3bar map sensor the cells get to spread out to reliably tune a RX7. Maybe for a piston car you have more leeway on tuning, but not for our cars. So perhaps you'll need to do more research.
Old Aug 14, 2005 | 09:34 AM
rxrotary2_7's Avatar
look at E... all fired up today!
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
