need fuel system help please..
Old Aug 10, 2005 | 03:15 PM
Panch78's Avatar
My engine is not working
Hello,
I am in the process of fixing and upgrading alot of things in my car (3rd GEN) right now. One of the things I want to upgrade is the Fuel System. I have a Walbro 225lph fuel pump which does not have AN fittings and an inline fuel pump with what i belive is a -6AN fitting , but I want to use -8AN braded fuel lines.
My question is:
1) Can I use -8AN lines knowing that I will have to use the -6AN fittings in my inline pump?
2) I am also planning to get the fuel rails from KGParts.com does anyone know what number fittings they use in their rail lines(I e-mailed keith but I am waiting for a responce figured I can just ask here now)?
Thanks for your help,
José
**I already did a search in these forums but I did not find a specific answer.**
Old Aug 10, 2005 | 03:19 PM
Panch78's Avatar
edit
I am sorry, question number 1) was supposed to say
1) Can I use -8AN lines knowing that I will have to use the -6AN fittings in my inline pump without endangering the pump, or the performance?
Old Aug 10, 2005 | 04:07 PM
papsmagu's Avatar
should i be the first one to tell him to SEARCH!!!!!!!!!!!!!!
........this should answer your fitting questions
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/picture-request-fuel-system-450027/
Old Aug 10, 2005 | 05:59 PM
wanklin's Avatar
Rob
The smartass answer would be to sell both pumps and put that money towards a proper pump with AN8 fittings. This is the route that I would suggest if it is within your budget to do so.
As for the sudden pressure increase/drop caused by adapting, I would assume that the pump would be fine as long as it is capable of operating with a reasonable amount of fuel being fed back to the return lines from the FPR. In other words I wouldn't try it if the pump is barely capable of feeding the engine at full bore. At the very least I would not immediately adapt to AN8 from the AN6 output of the pump for fear of cavitation as a result of the sudden change in line diameter/pressure drop. I'd probably adapt the line a little further down the line after the pump and use an AN6 feed to the pump.
I think when all is said and done you will be no better off with 8 than 6 and if you are dead set on 8 then a proper pump is probably the best bet.
good luck!
Old Aug 10, 2005 | 06:21 PM
Trexthe3rd's Avatar
If you are not planning on pushing over 600whp from your car why would you need anything larger than -6AN line??
Old Aug 11, 2005 | 07:04 AM
Panch78's Avatar
https://www.rx7club.com/showthread.php?t=450027
This is the answer i was trying to avoid when i said "I had already searched." Thanks alot for sending me to a thread I had already looked at. Obviously you did not understand my question , but lucky for me someone else did.
Thanks alot Wanklin and Trexthe3rd for the answers i was looking for.
Snook
21
Sep 1, 2015 06:32 PM
82streetracer
Aug 23, 2015 09:28 AM
