Oxygen Sensor Location/Installation?
Old Aug 10, 2005 | 12:15 PM
California Dreaming's Avatar
The Captain
Question Oxygen Sensor Location/Installation?
Pretty straight forward, I want to change my oxygen sensor but I am not quite sure where it is located. Help would be appreciated.
-Neal
Old Aug 10, 2005 | 12:36 PM
Madmax670's Avatar
rotors + turbos = bliss
DL the FSM
Old Aug 10, 2005 | 12:39 PM
Booztd 3's Avatar
Low boost is 18psi *)
You need to remove all the rubber piping that leads to the intake box (minus the larger, lowest one) I think there is 1 large (like 2" diamter) pipe and 3 smaller pipes that come off
If you look down to the side of the engine, looking at the exhaust manifold, you'll see it sticking out (points towards the front of the car at an angle) You'll be able to get a socket and a ratchet down there. Should be a 15-20 min job
Old Aug 10, 2005 | 12:46 PM
The Captain
That easy eh? Thanks alot.
Old Aug 10, 2005 | 12:59 PM
1QWIK7's Avatar
White chicks > *
agreed
i was changing my intake pipes and i looked down towards the y pipe and i saw the o2 sensor and im like, damn its only right here? wow, that looks easy to change..im about to change mine since everything is already out..
Old Aug 10, 2005 | 02:03 PM
Booztd 3's Avatar
The only thing that will probably give you trouble is there are some AC lines that travel up against the chassis on that side. It may make it a bit difficult to maneuver the ratchet around
Old Aug 10, 2005 | 02:56 PM
Sled Driver's Avatar
The Anti-Prius
-Neal
Buy a shop manual..........
Did you find the gas cap yet? Or did you have to ask someone on the forum where it's located?
Just because it has a rotary engine doesn't mean it's from Mars.
Use a little common sense. You can pretty much can conclude that it's in the exhaust system somewhere.
Add to that, it's normally located close to the engine.
Jack the car up & look for it.
Hint....
Short sliver thing with a wire comming out the end, sticking out the precat/down pipe.
People who ask simple mechanical questions like this worry me. Are you really capable to working or your car without adult supervision?
Old Aug 10, 2005 | 03:37 PM
The Captain
Hint....
Grow up. I already received an answer so why did you even bother posting? Don't you have something better to do with your time than complain? I just started working on my car so excuse me if I didn't know where a oxygen sensor was. Clearly I am not yet at your almighty level of vehicle intelligence.
Old Aug 10, 2005 | 03:50 PM
moehler's Avatar
People who ask questions and try to learn something for themselves worry you?? come on, man .
People have to start somewhere when it comes to working on cars; "California Dreaming" is starting with something fairly simple and trying to do it himself and that's a good thing.
Old Aug 10, 2005 | 03:59 PM
The Captain
Thanks for the support moehler. I never expected to be flamed for trying to learn.
Old Aug 10, 2005 | 05:49 PM
The Anti-Prius
See your already wising up. Good job junior. Now don't stay up too late working on that pesky sensor. It is a school night and we all know you have a lot to learn!..
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
