Should I drive this far in my new RX?
Old Jan 12, 2002 | 09:58 AM
Mschafe's Avatar
Where did my 7 go?
Just got my 83GSL. Seems to run and drive great... I need to make a drive to Chicago next weekend. Its about a 7 hour drive. Do you think the RX would make it without too much trouble? I'm usually nervous to drive older cars far, but this car would be perfect to take. Anything special I need to keep in mind?
Thanks,
Matt
Old Jan 12, 2002 | 10:01 AM
rxtasy's Avatar
do an oil change before you go and check all the belts/hoses etc. If the car runs good now you shouldn't have a problem. I like long trips in the rex, it makes me think i actually get GOOD gas mileage!!
Old Jan 12, 2002 | 11:34 AM
peejay's Avatar
Old [Sch|F]ool
YEah, the worst thing you can do for your car is city driving... the best thing is long-distance stuff. I (used to) regularly do 500+ miles a day in my SA.
Old Jan 12, 2002 | 01:16 PM
yayarx7's Avatar
Are you Nucking Futs?
the only breakdown I have ever had was the rear wheel bearings failing massively on me about an hour from the house....I should have known better they were making god awful noises forever. (I had an alternator freeze up once but that is expected from time to time.)
make that drive
Old Jan 12, 2002 | 08:51 PM
Sure no prob., I once took my old 81gs with the common o-ring oil leak all the way from colorado springs to new jersey and back!! with no problems.
Old Jan 12, 2002 | 11:11 PM
error402's Avatar
#!/sup_mod/üb3rg33k
Everything should be fine, just make sure you check over the basics.
Oil, belts, hoses, coolant etc.. Carry some oil and coolant with you just in case too.
Old Jan 13, 2002 | 12:01 AM
Took my 84 from Winnipeg to Calgary about 800 miles one way, had no problem car had more than 150,000 miles on it.
Old Jan 13, 2002 | 11:38 AM
Mschafe's Avatar
Where did my 7 go?
Thanks!
Thanks everyone.. I feel a lot more comfortable driving that distance, so I will do it. I will give everything a good check-over before i go.
Matt
Old Jan 13, 2002 | 03:09 PM
7addict's Avatar
One last thing before you go! If you just got the car change your fuel filter. To be comfortable with your desicion also do an hour to hour1/2 straight city drive first. If you have no over heating problems or anything that makes you nervous than fly like the wind. By the way you probably will be tempted to fly so a radar detector is a good idea!
Old Jan 13, 2002 | 07:55 PM
Pele's Avatar
Right near Malloy
I wish I could have a radar detector... Damn pigs.
Do you know you can get a ticket for flashing you highbeams at oncoming traffic to warn them of a speed trap ahead of them... Obstruction of justice or some ****..
Radar detectors are flat out illegal here in VA.
Old Jan 14, 2002 | 12:14 AM
7addict's Avatar
Did you actually get a ticket for flashing your high beams ?
Old Jan 14, 2002 | 08:44 AM
mdooner's Avatar
you're not supposed to flash your high beamers, you're supposed to blink your lights (turn them on and off a few times)
Old Jan 14, 2002 | 11:36 AM
RotoHead's Avatar
mdooner, good advice for driving the rex. Bad when I am driving my wifes POS. She has those day light blinding lights. As for radar detectors, just practice ripping one off the dash in record time. But make sure you don't leave the common suction cup marks or anything. Or if you use velcro just have like a little note pad or something that you can stick in place of the detector if you get pulled over. Us forgetful people should never drive anywhere without a note pad, our wives would get mad if we forgot to drop by the store or something. Isn't it amazing though, that there was a device created specificaly for breaking laws! Just too funny if you ask me.
Old Jan 14, 2002 | 11:49 AM
jimmyv13's Avatar
Round&Round not Up&Down
I heard that VA troopers have radar detector detectors, any truth to that?
About long drives....it's all about how confident you are in your car. I could leave at the drop of a hat and drive to CA if I needed to. Grab an oil filter and some oil for a change and I'd be gone. I keep extra plugs, wires, belts, starting fluid, cables, fuses, small gas can, and a little bit of all of the misc fluids that I need in my storage compartments and my tool box in the hatch just in case. I know my car would make it, barring I don't hit Bambi or a drunk decides to play bumper cars
Old Jan 14, 2002 | 01:03 PM
brownmound's Avatar
Anytime baby!
Pantyhose makes a good belt emergancy replacement. Carry some, or just get a ***** when you break a belt.
Right on-
Old Jan 15, 2002 | 02:52 PM
WackyRotary's Avatar
standard combustion
Some rador detectors come with VG2 Cloaking. This feature essentually turns off the detector for 30seconds and then checks for the "rador detector dectector" again if it doesn't it will go to normal mode. I've had mine since '96 and can say with out resevation that its one of the best investments ever! But I have gotten one speeding ticket since '96. But it has saved my *** numberous other times. They are not designed to make your car invisble, just give you some prior warning if they are in the area with in 1-2miles. I got my ticket from a instant-on radar so I didn't get a break there. Helps to have other drivers going the same speed your are. Thats why I tend to go the speed limit for a while till a pack of fastee's go by and join up them!
Old Jan 15, 2002 | 10:09 PM
brownmound's Avatar
Anytime baby!
Just today on the news they announced that Texas State Troopers now have radar detector detectors....only for use on trucks though, as radar detectors are still legal in Texas for passenger vehicles.
Right on-
whinin
Mar 30, 2019 07:53 PM
troym55
23
May 25, 2016 12:42 PM
