tips on installing strut-tower bar....
Old Jul 26, 2005 | 12:23 PM
Archangels's Avatar
- Make Haste -
any tips on installing a strut-tower bar in an S5?...
i'm sure it's pretty simple and basic but always better to be safe then sorry....
Old Jul 26, 2005 | 12:29 PM
neofreak's Avatar
accept no imitations™
Remove the 4 bolts on each side.
Put bar on, put bolts back.
Old Jul 26, 2005 | 12:32 PM
Archangels's Avatar
- Make Haste -
yeah but how tight do i tighten them?...
whats with the bolt right on the bar, it can be tightened either way, towards the ends of the strut bar or towards the bar itself, i assume this just holds the bar in place the way i want it...?
Old Jul 26, 2005 | 12:51 PM
RXgirl7's Avatar
IT LIVES!!
if you really wanna get fancy, jack the car up so the suspension hangs free and isnt preloaded. at least thats what the directions for my bar said.
try not to scratch it!
Old Jul 26, 2005 | 01:00 PM
dennis blackstone's Avatar
made my own works great
Attached Thumbnails tips on installing strut-tower bar....-photo-84.jpg   tips on installing strut-tower bar....-photo-115.jpg
Old Jul 26, 2005 | 01:11 PM
Archangels's Avatar
- Make Haste -
dont wana get fancy, i just want it installed....
Old Jul 26, 2005 | 01:13 PM
J-Rat's Avatar
Alcohol Fueled!
Jack your car up a little, makes the install alot easier.
Old Jul 26, 2005 | 01:16 PM
Archangels's Avatar
- Make Haste -
easier?... how so?...
i thought with it on the ground and it sitting the way it sits that it would be easier to install because nothing would move....
and thats how it would sit when the car's on the road....
ahh this is confusing....
Old Jul 26, 2005 | 01:43 PM
Archangels's Avatar
- Make Haste -
any specific way the bolts should be tightened down?...
i assume i should do this on a pretty flat surface?...
Old Jul 26, 2005 | 02:30 PM
SureShot's Avatar
Seduced by the DARK SIDE
You jack the front to pre-load the bar some.
If it's the type that you have to remove all 4 bolts, jack it but leave just enough suspension pressure to keep the pillow mount from moving.
The brace makes more of a difference with an upgraded suspension than with a stock suspension.
Check the clearance at the top of the alternator.
You don't want it to hit when the engine torques over under acceleration.
Old Jul 26, 2005 | 02:33 PM
Natey's Avatar
Don't torque the bolts too much. I've heard a couple stories about the bolts on the strut tower breaking off.
Old Jul 26, 2005 | 03:13 PM
Archangels's Avatar
- Make Haste -
****, how much should i torque the bolts then?...
i was going to tighten them as bloody hard as i could by hand....
it's all good, i have full coil overs, this strut bar now and a sway-bar kit on it's way....
:P
handle like it's on rails?, i think so....
Old Jul 26, 2005 | 07:04 PM
S2-13BT's Avatar
Just tighten them down good and tight. By hand though, don't get a rattle gun on there!
Check them a couple days later to make sure they're still tight, and you'll be fine.
EDIT: I had a quick look in the FSM, and the tightening torque for the 4 bolts at the top of the strut is 22-27 ft-lb. Hope that helps!
Old Jul 26, 2005 | 07:36 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
You're way too paranoid man. Just do it and be done with it.
Old Jul 26, 2005 | 08:19 PM
Archangels's Avatar
- Make Haste -
kool, thanx....
:P
Old Jul 26, 2005 | 09:10 PM
SwiftTone's Avatar
this thread is kind afunny...if you are paranoid about over tightening of under, get a torque wrench, a manual, and you wont have to worry anymore.
Old Jul 26, 2005 | 09:12 PM
daten's Avatar
picture of the new bar installed?
Old Jul 26, 2005 | 09:19 PM
Agent_D's Avatar
rawr
its not hard, we installed the one in my wifes vert with it just sitting on the ground, we made it a tight fit from side to side, dont know if it makes a difference either way.
Old Jul 27, 2005 | 01:31 AM
Archangels's Avatar
- Make Haste -
i installed it, will have pics soon....
i tightened everything as tight as i could, the mounts ( sides ) didnt really mount up flush, so i tightened the hell outa them and they "adapted" do the strut tower....
where the bar connets to those ends i tightened that as tight as i could too, the bar doesent move at all now....
Old Jul 27, 2005 | 02:54 AM
Archangels's Avatar
- Make Haste -
here's a pic i just took, it's 2am.... i swear my neighbors think i'm nuts....
the ends where the chrome bar connects to the black ends, i tightened those as tight as i could, they dont flex or move....
Old Jul 27, 2005 | 01:00 PM
Archangels's Avatar
- Make Haste -
oh, and how am i suposed to put oil into my car now, the cap wont clear the bar, LOL!...
Old Jul 27, 2005 | 03:13 PM
vex's Avatar
vex
Clean engine, sweet. What kind of bar is that?
Old Jul 27, 2005 | 11:50 PM
Archangels's Avatar
- Make Haste -
to be honest with you dude, i have no idea....
it's VERY VERY shiney and shipped only cost me $60....
next time i go to their shop i'll check the brand for you, you get no instructions or anything, thats why i made this thread, hahaha....
Old Jul 27, 2005 | 11:53 PM
civic slasher's Avatar
Would the same aply to the instalation of a front strut bar?
Old Jul 28, 2005 | 12:31 AM
Archangels's Avatar
- Make Haste -
this is a front strut bar dude....
i assume his tips meant for the front one....
Snook
14
Oct 1, 2015 10:56 AM
apooch
Sep 4, 2015 10:27 AM
tiger18
Sep 3, 2015 08:27 PM
