-se intake
Old Jan 12, 2002 | 12:44 AM
hamster's Avatar
-se intake
Anyone have good ideas for improving the intake on a gsl-se?
Old Jan 12, 2002 | 10:33 AM
Max7's Avatar
Admitted Sevenaholic
I got a couple that have worked well for me.
remove the 2nd'ary throttle plates (better throttle response)
Cone filter with adapter (more air)
Cold/Ram air box (Colder is better)
mods I'm working on now
Pinnapple racing 6 port sleeves
completely removing the ACV from the lower manifold
then construct a better heat shield for it
this is what it looks like done to a 2nd gen intake, I'll do the same to my SE
http://max7.rx-7.org/modifications/intake-manifold.htm
Old Jan 12, 2002 | 12:01 PM
smnc's Avatar
EliteHardcoreCannuckSquad
What are Pinnapple racing 6 port sleeves?
Old Jan 12, 2002 | 12:26 PM
FJ's Avatar
FJ
You can read about them here:
http://www.pineappleracing.com/Prod-pr6pi.html
=John.
Old Jan 12, 2002 | 12:45 PM
peejay's Avatar
Old [Sch|F]ool
Geez Max7 that manifold is going to be nothing but weld beads when you're done with it!
I like it.
Old Jan 12, 2002 | 09:20 PM
Max7's Avatar
It will be interesting, going to grind all the welds smooth, then put a full polish on it to match the header
I like it.
Old Jan 13, 2002 | 10:26 AM
Max,
So you have comepletely removed the secondary throttle plates? What other tips can you give a newbie like me not looking to spend lots of $$ on the RX?
Here is the list so far:
Adapter plate and cone filter(www.intenseperformance.com) on the AFM
Air Pump removed & ACV removed and covered with RB plate
Racing Beat Header installed to cat to muffler - Vroooooom
AC removed
Clutch Fan removed - $10 Oldsmobile unit installed (zip tie )
Timing Advanced slightly
NGK plugs and Wires
Thanks for any advise -
Old Jan 13, 2002 | 11:07 AM
Max7's Avatar
I removed the plates and rods and all coolant lines. then blocked off the holes with some bolts and JB Weld.
Build a cold air box, keep the heat away from the intake
Old Jan 13, 2002 | 07:36 PM
rx7 Nut's Avatar
I don't know if it will help much but I and going to try and port out the inside of the the afm. Seeing how its the biggest restriction in the intake I'm thinking that any little bit would help.
Old Jan 13, 2002 | 08:54 PM
Max7's Avatar
might be worth a shot, but without the opening up the next restriction, the throttlebody it may not be noticable
