Fuel Pressure Regulator
Old Jul 25, 2005 | 09:35 PM
SChema's Avatar
1988 Turbo II
I'm not sure if anyone has covered this but;
what are some good indications of a bad FPR?
and what are some symptoms of an FPR going out?
Old Jul 25, 2005 | 09:57 PM
SChema's Avatar
1988 Turbo II
I'm leaning towards a fuel problem, the car wants to just idle, I can barely raise the RPMs above 1500. i've got good fuel pressure, had the injectors cleaned, replaced the fuel filter, and I couldn't see any fuel leaks either.
Old Jul 26, 2005 | 01:13 AM
Archangels's Avatar
- Make Haste -
i had a simular problem, might wana check your fuel pump, it might be dying....
Old Jul 26, 2005 | 06:44 AM
RETed's Avatar
Install a fuel pressure gauge, and it'll be obvious.
-Ted
Old Jul 26, 2005 | 08:26 AM
HAILERS's Avatar
HAILERS
Your confusing some of us. You just stated you have good fuel pressure. If you have good fuel pressue the fpr is good. Tapping in a fuel pressure gauge like was stated above is the only way to know for sure.
At idle the pressure should be about 28-30psi and if you idle and pull off the vacuum hose from the fpr the pressure should be about 37-39 psi.
If it idles fairly decently and won't rev above 1500 it might be a corrupt tps. Disconnect it and try again.
You real sure your sparkplug wires are on right? Your timing is spot on? Using a timing light?
Old Jul 26, 2005 | 11:37 AM
SChema's Avatar
1988 Turbo II
I checked the fuel pressure before the FPR, while the car was off. I have checked the spark and I had decent spark too. The TPS though, I ran a couple of tests from the book. The TPS ohmed out fine and it swept fine through opened and closed throttle. There could be something else that I;m missing. I'm pretty sure the timing is fine, because it was driveable before; I was driving when this started to happen. The car was fine up to that point.
Old Jul 26, 2005 | 05:12 PM
SChema's Avatar
1988 Turbo II
There isn't a "limp-home" mode on RX-7's right?
Old Jul 26, 2005 | 05:56 PM
HAILERS's Avatar
HAILERS
Only on series five. None on series four that I'm aware of.
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
