AFM Help Please!!
Old Jul 24, 2005 | 11:00 PM
TurboRotary13b's Avatar
AFM Help Please!!
Ok.. I was driving home last night and all of the sudden the car wants to die.. well I knew right away what it felt like. I got it home and pulled the plug off the afm and started it up... and it acted exactly the same.. so Im guessing that either my afm is screwed or its in the wiring. Is there a way that I can test to see which it is?
Old Jul 24, 2005 | 11:05 PM
SonicRaT's Avatar
Super Raterhater
Could be a vacuum leak, faulty AFM (as in the fuel switch), no compression, etc. It could be a number of things.
If you believe it's the AFM, you can try to jumper the fuel pump connector (yellow, near the AFM/pressure sensor harness)
Old Jul 24, 2005 | 11:18 PM
HAILERS's Avatar
HAILERS
I'm not real big on non monkeyed with afm's causing problems......but there is a section in the FSM that gives you some basic resistances to look at.
A even better way is to backprobe with a digital meter, the afm's output pin AT the ECU with all the plugs on everything. Then slowly shove the vane in the afm to the rear. The voltage should drop from a figure of approx 4vdc at the beginning to approx a half volt when the vane is all the way aft. The meter shouldn't show any strange readings as you move the vane aft. Such as the voltage going down and at some spot going back up as you move the vane aft.
The fsm checks the opening/closing of the fuel cut switch in the afm, the resistance of the air temp sensor inside the afm, the resistance of the *pot* with the vane fully closed and I think with the vane all the way open.
Like the RAT said, if you jumper the fuel pump check connector you eliminate the possibility of the afm's fuel cut switch being the culprit.
Old Jul 24, 2005 | 11:33 PM
alright.. thanks guys.. Ill try that tomorrow.
Old Jul 24, 2005 | 11:36 PM
3RotorRocket's Avatar
had the same problem way back, it was the afm
Old Jul 26, 2005 | 06:20 PM
Will a S5 N/A AFM work?
Old Jul 26, 2005 | 06:27 PM
SonicRaT's Avatar
Super Raterhater
It will get it started, but it'd be a bad idea to drive on it that way. (Unless this is a s4?)
Old Jul 26, 2005 | 07:14 PM
no.. this is a S5 TII.
Old Jul 26, 2005 | 07:20 PM
SonicRaT's Avatar
Super Raterhater
Ok, then it should get it started, but as I said, running on it wouldn't be advisable.
Old Jul 26, 2005 | 08:25 PM
****.. it looks like its gonna be hard finding one for a S5 TII.. and mazda wants $1200 for a new one. lol!
Old Jul 26, 2005 | 10:20 PM
mashing rx7's Avatar
MAN it sucks when dealers and auto shops CHARGE UP THE ***, try mazdatrix or ebay,
IF it turns out not to be your AFM b/c i'm going through the same thing,
it wouldnt hurt to get your Alternator checked and your grounds as i had that problem(s) with bad alternators.
AND VACUUM LEAKS!!! make sure you dont have any vacuum leaks b/c turbos dont like any leak what so ever. I'm currently in the process in changing all my vacuum hoses with silicone ones..
Old Jul 27, 2005 | 08:41 AM
RETed's Avatar
Originally Posted by mashing rx7
MAN it sucks when dealers and auto shops CHARGE UP THE ***, try mazdatrix...
What do you think Mazdatrix is???
-Ted
Old Jul 27, 2005 | 11:47 AM
Mazda trix is expensive. But a very good RESORT to when you are stuck. GO EBAY!!!
R.O.D
34
Jan 6, 2016 12:09 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
86glxNA
Aug 22, 2015 08:54 PM
