crank angle sensor help please!
Old Jul 24, 2005 | 10:35 PM
88 GRIP's Avatar
I know this sounds crazy but while putting my engine back together I could not for the life of me find where the crank angle sensors 4 prong clip plugs into!!
Is it into the engine harness or something else? I already looked at the FSM.
Pictures would be awesome. .............THANKS!
Old Jul 24, 2005 | 10:42 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
The CAS's 4 prong connector is in with the alternator wiring harness.. its not on the main harness.
Old Jul 24, 2005 | 11:35 PM
HAILERS's Avatar
HAILERS
Look and see if it's hiding under the solenoids on the left side of the engine. The solenoids connectors are a part of the EMISSIONS harness. The CAS connects to the ENGINE harness which includes the LARGEST wire on the alternator (not the small two wire connector on the alternator). The plug should be white in color.
Old Jul 24, 2005 | 11:55 PM
RotaryEvolution's Avatar
Sharp Claws
follow the connector from the back of the alternator, the CAS plug should not be far down along that harness.
oh wait, that was already said 2 times!
Old Jul 25, 2005 | 12:52 AM
88 GRIP's Avatar
Thanks, as soon as I get home I should be able to figure this out. thanks for the advice everyone.
NEWGENRX7
Jun 26, 2019 12:20 AM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Monsterbox
Sep 11, 2015 03:29 PM
