Removed my oil pan and ....
Old Jul 22, 2005 | 01:32 PM
BOOSTED Vert
This is what I found... Its silvery kinda shiny.
Old Jul 22, 2005 | 01:37 PM
johnnyg's Avatar
What part are you talking about? The shiny looking fluid on top of the oil? If so, gas would be my guess. But if you're talking about that powdery looking stuff, my guess would be metal. Try picking it up with a magnet.
Old Jul 22, 2005 | 01:40 PM
turbine's Avatar
ouch, this is never a good sign your motor was probably run low on oil at one time(or lots of times) causing some internal wear on your main barrings or other engine componits only thing to do is to keep up on your oil changes
Old Jul 22, 2005 | 01:49 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Yep... That, my friend, is pulverized rotor and stationary gear bearings!!!!!
Old Jul 22, 2005 | 01:59 PM
BOOSTED Vert
Well I kinda have an Idea of what it is... on the last rebuild I had water going into my oil pan.... So I suspected a bad coolant seal... I immediately used the block weld **** and it didnt work, so i took it apart in a weekend and put it backtogether... Me being lazy as ***, I didnt clean the oil pan at all, so its most likely blockweld and on top of that, I found a leaf..... Now mind you, this is in a high performance turbo motor, hopefully the metal fragments dont *** up my turbo... Anyways, im an lazy *** idiot and sorry for posting this ****...
Btw, I removed the oil pan while the motor sits in the car... The oil leaks was giving me fines, so I had to do this...good thing I found it, I wonder what the metal fragments from block weld would do to bearings??
FD7KiD
15
Feb 26, 2021 10:12 PM
rocker1337
16
Sep 6, 2015 11:28 PM
FD7KiD
Aug 17, 2015 11:50 PM
