how do u tilt da engine to alighn tranny?
Old Jul 21, 2005 | 06:30 PM
RomeoFC3S's Avatar
i'm currently replacing my clutch..
i'm for sure gonna have a hard time lining up the engine and tranny..
i heard that i should atleast tilt the engine toward the rear of the car, the question is..
how and where would be the propper way to do this?..
i've only got two hydraulic jacks
any tips guys
Last edited by RomeoFC3S; Jul 21, 2005 at 06:39 PM. Reason: to have notification on any replies
Old Jul 21, 2005 | 06:40 PM
RomeoFC3S's Avatar
any tips guys
Old Jul 21, 2005 | 07:52 PM
Tournapart's Avatar
RIP Icemark
i was about to rip on you for the title, but then i see it is a joke, right? ha
Old Jul 21, 2005 | 07:54 PM
Tournapart's Avatar
RIP Icemark
but seriously, go rent a transmission jack from an auto parts store, you wont regret it, and your transmission wont fall of the jack and get all fucked up. and with a tranny jack you wont need to 'tilt' the engine the jack will be sufficent for line up.
Old Jul 21, 2005 | 08:05 PM
tawd's Avatar
I put a tranny in an 88 a long time ago... The transmission arent terribly heavy. All I did was pu a jack under the lower pully in the front of the engine. just gave it a couple pumps to get the rear of the engine to lean down a little. I had the car way up on jackstands and crawled underneath and got the transmission up there by hand and had a buddy start a couple of the bolts to hold it up. It was actually really easy. Just make sure you align your clutch(you should get an alignment tool with your clutch kit) when you put the clutch on and it should go pretty easy for you. Good Luck!
Old Jul 21, 2005 | 08:06 PM
Tournapart's Avatar
RIP Icemark
if youve never done this before i would still go with the tranny jack
Old Jul 21, 2005 | 10:20 PM
Curtisleeyoung's Avatar
Clutch allighnment tool make sure you have the right one and it's propperly alighned les you trying to put a square shaft in a triangle hole, (it's an expression)
Old Jul 21, 2005 | 10:26 PM
xaymaca's Avatar
Spittin' Seals
I used a prybar on the front cover with a piece of wood to chock it once it was tilted forward.
Worked for me.
Old Jul 21, 2005 | 10:31 PM
RETed's Avatar
Bah, engine hoist + engine tilter...
-Ted
Old Jul 21, 2005 | 10:34 PM
RETed's Avatar
Doh, duplicate thread. :P
-Ted
Old Jul 21, 2005 | 11:04 PM
AcidShock's Avatar
Eet fase
You could also get a six pack to entice a buddy to come over and push on it for a little while.
Old Jul 22, 2005 | 02:32 AM
RomeoFC3S's Avatar
i dnt have a hoist
no other way? ^_^
btw RETed, just wanna say i'm a big fan of yours..i see your usename here alot...thanks for all the help..i aslo visits your page often when i need info
Old Jul 22, 2005 | 02:45 AM
RomeoFC3S's Avatar
wow thanks for the replies..u guys are the man!..i'm gonna go and tackle my tranny and get back at you guys..
Old Jul 22, 2005 | 04:00 AM
bingoboy's Avatar
Lava Surfer
if your motor mounts are old, you can say goodbye to them. tranny work is a good time to replace them.
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
sYnth.
Aug 19, 2015 06:27 PM
Wicked93gs
Aug 17, 2015 12:14 PM
