AUdio problems
Old Jan 10, 2002 | 11:20 AM
Question AUdio problems
Doesn't seem to be a fuse blown but once i got my new deck in, it turned off with the dome lights door lights and rear hatch. Can't figure out what it is.
Old Jan 10, 2002 | 12:23 PM
Icemark's Avatar
Dan,
YOU BLEW THE DOME (sometimes also called ROOM) FUSE.
REPLACE THE 7.5 AMP FUSE.
Old Jan 10, 2002 | 12:33 PM
Icemark's Avatar
Again you need to check you are not drawing too much for the new radio. Unless you had the factory accoustic EQ system, there is only a 7.5 amp fuse.
Most aftermarket high power radios draw more than that. 10 amps is typical.
Now if you had the factory accoustic EQ system then there is a 25 amp fuse.
If you are blowing the 25 amp fuse you need to fix your wiring of the radio, you did something wrong.
Old Jan 10, 2002 | 04:20 PM
fixed the problem, bad terminal not bad fuse, thanks though
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
