Microtech lt8s installed but no start
Old Jul 6, 2005 | 10:55 PM
MrSparkle's Avatar
i'm disrespectful to dirt
i just put in my lt8s but my fc doesn't start. it runs fine after push starting but it doesn't want to fire up. i haven't touched the timing yet so could that be my problem? i have spark and fuel but it just doesn't want to fire up.
Old Jul 6, 2005 | 11:50 PM
skim41's Avatar
I have had this problem with my FD. To me it seems like a vacuumleak, maybe you forgot to cap off a nipple somewhere.
Old Jul 7, 2005 | 12:25 AM
MrSparkle's Avatar
i wish that was the problem. i have no rats nest crap and i just checked right now and no vacuum leaks.
also i have my starter wired directly to ignition but i doubt that has anything to do with it.
Old Jul 7, 2005 | 01:49 PM
skim41's Avatar
Have you checked for compression etc? I had the same problem last year, crank but no start. After pull start no problem. Turned out that I left 2 vacuum nipples open at the bottom of the LIM at the engine side. After these were plugged no more problems.
Otherwise check for compression and unflood when necessarry. Does the engine sound like its want to start?
Old Jul 7, 2005 | 02:38 PM
MrSparkle's Avatar
haven't checked compression but it used to fire right up no problem with the stock ecu a couple days ago. it just cranks and cranks but no start. the battery got kind of low so i'm charging it hopefully that helps.
Old Jul 8, 2005 | 01:31 AM
skim41's Avatar
ok, also check the sparkplugs on fuel and clean when necesarry.
Old Jul 8, 2005 | 03:35 PM
MrSparkle's Avatar
turns out the 12v ign source i used would turn off while cranking just like dale said. starts and runs perfect now.
Old Jul 9, 2005 | 12:34 AM
skim41's Avatar
OK, super!
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Aug 14, 2015 04:18 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
