stationary gear HELP
Old Jun 30, 2005 | 07:46 PM
T04Eneedy's Avatar
adiabaticly inefficient
Question stationary gear HELP
ok,so i decided to use the rx8 stationary gears on my big port s4 t2.my question is,since the rx8 stationary gears use the FD thrust bearings.do i need to buy them?because im using the 8.5:1 s4 rotors/counter weight.would it make a difference to use the s4 thrust bearings?or do i have to buy the FD thrust bearings?
Old Jul 2, 2005 | 06:36 PM
T04Eneedy's Avatar
help
bump
Old Jul 4, 2005 | 11:44 AM
T04Eneedy's Avatar
Unhappy
come on i know someone has run FD stationary gears on a s4.im just asking how....
Old Jul 6, 2005 | 12:17 PM
rotaryengineering's Avatar
Thumbs up You'll need to purchase the FD front assembly
I have run a similar setup using high compression rotors with Turbo II outer cast irons and a 12A center cast iron. The front/rear stationary gears were from a 1993 engine I had in my garage. It will work you just have to use the entire front assembly.
Good Luck
Albert
Old Sep 14, 2005 | 10:12 AM
full-cruise's Avatar
D.I.L.U.S.I.
im in the same boat rite now and that whole 12a hybrid totaly threw me off. is there anybody that can shine some light on how to use the rx8 or S6 gears in the S4 T2 motor?
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
