15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""
Old Jun 20, 2005 | 08:58 PM
theone81's Avatar
Red face 15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""
Apparently Im having problems with my New Project Kics Wheel spacers (15mm), I had other spacers pictured below to "Eliminate" the Rubbing sound" and it did "A little" But when I put the new Wheel spacers it made matters workse now every time the tire turns it makes a thumping sound..??? how is this do you think i its the "TIEN DRESSMASTERS" cause the springs in the front look aparrenly bigger.. maybe thats why its rubbing.... any thoughts.... answers from any of you guys...?
Attached Thumbnails 15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-001.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-002.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-003.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-004.jpg
Old Jun 20, 2005 | 09:07 PM
slpin's Avatar
7th Heaven
you could use rims that actually belong in your car...
Old Jun 20, 2005 | 09:11 PM
felixwankel88's Avatar
hahahaha, that would solve the prob lol
Old Jun 20, 2005 | 09:16 PM
trochoid's Avatar
Old Fart Young at Heart
Throw those pos's away. You need hub centric spacers if you want to do this properly, and safely.
Old Jun 20, 2005 | 09:41 PM
slpin's Avatar
7th Heaven
no
you need new rims with different back spacing
Old Jun 20, 2005 | 11:03 PM
trochoid's Avatar
no
I don't disagree with that, even some of the aftermarket wheels, with proper offset, need hubcentric rings. If he wants to use his current rims, that is his best option.
Old Jun 20, 2005 | 11:16 PM
theone81's Avatar
they are TII rims....
Old Jun 20, 2005 | 11:54 PM
RETed's Avatar
Why are you using those spacers?
Are you sure they are 15mm?
15mm is like over half an inch!
They don't look like over half an inch in the pic?
If they are true 15mm spacers, the rear lug nuts would fall off - do you have longer studs in the back?
-Ted
Old Jun 21, 2005 | 12:20 AM
slpin's Avatar
7th Heaven
you installe dhte struts wrong?
why would it rub?
Old Jun 21, 2005 | 12:43 AM
theone81's Avatar
Question
-Ted
Thw Wheel Spacers are 5X114.3 SIZE15MM
AND MY WHEEL IS 16x7 w/ 114.3x5 bolt pattern (tURBO mODELS)
NASTY SOUNDS" WHEN TURNING EITHER LEFT OR RIGHT "ACCELERATING"
DRIVNG STRAIGHT: ~~~~THUMB~~~~~~~THUMB~~~~~~THUMB~~~~~~~
Struts: Tein Dress up Master S. Tech http://tein.com/ti/m62.html
Attached Thumbnails 15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-005.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-006.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-007.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-008.jpg   15mm Wheel Spacers made the Wheels go "Thump" Thump" before they went "Squeek"PICS""-picture-009.jpg
Old Jun 21, 2005 | 01:00 AM
ddub's Avatar
i am legendary
Hmm, you really shouldn't be having those problems with stock TII wheels.
Old Jun 21, 2005 | 01:08 AM
slpin's Avatar
7th Heaven
drew - exactly what i was thinking
Old Jun 21, 2005 | 01:13 AM
rotarygod's Avatar
Rotors still spinning
This is probably a dumb question but are you sure all of the lugnuts are tight?
Old Jun 21, 2005 | 01:19 AM
theone81's Avatar
Unhappy
lemme check
Old Jun 21, 2005 | 01:26 AM
JLa's Avatar
JLa
Just a couple of guess', but have you checked your wheel bearings? If you did, how fresh are your tires, maybe they're out of balance or out of round if they're old?
Old Jun 21, 2005 | 01:39 AM
slpin's Avatar
7th Heaven
Originally Posted by theone81
lemme check
^^^ you are kidding..... right?
Old Jun 21, 2005 | 03:55 AM
RoadRaceJosh's Avatar
Hobby or mental illness?
I want to see a picture of the back side of the wheel where it meets the hub. I know this should be really obvious, but people do screw this up... Does the wheel sit flush against the hub?
Also, with the wheel bolted on and the car jacked up so that it's off the ground can you move the wheel in and out at the top and bottom or side to side?
Old Jun 21, 2005 | 07:59 AM
Renegade_07's Avatar
THINK
hey
i have the same set of springs on koni yellows and i am having the same issue with rubbing on stock 15 gxl rims. I am looking into changing rims soon and i too was going to get spacers. But now reading this i think should get new springs
Old Jun 21, 2005 | 10:25 AM
JSmith0101's Avatar
Play Well
Yeah, check the lugs, then check them again. Then check your studs to see if they are stripped out somewhere. When I sheared a stud I got a thumping sound and had to limp home. So make sure everything is kay and there is no stripping the on studs, because that is bad. And if you're trying to put these new tires on your original studs, it will never happen, you'll have to replace them.
Old Jun 21, 2005 | 08:54 PM
theone81's Avatar
PROBLEM SOLVED LT wheel was loose due to my stupidity of not tightning "One lugnut" yes ONE lugnut.....
Old Jun 21, 2005 | 11:55 PM
JDuncan's Avatar
ROLL YOUR FENDER LIPS... Or is that not a big gouge going around the outside edge of your tire? Between your lowering springs, and your spacers pushing the wheels out towards the fender, that might be the source of the other noise. (not the thumping, which was the lugnut noise)
Old Jun 22, 2005 | 12:22 AM
crashdummy's Avatar
where did you get those spacers anyway?
Old Jun 22, 2005 | 01:24 AM
theone81's Avatar
www.RotaryXecret7.com
Old May 2, 2008 | 05:52 PM
CarzArKoo1's Avatar
any JDM shop or online store, they sell kics spacer.
Old May 2, 2008 | 07:01 PM
freemanrx7's Avatar
^Hold On
I used 1/4 spacers on my wheels(17 inch CIVIC SI) NO problem with noise.
