Power FC CEL myth or fact...?
Old Jun 19, 2005 | 07:37 PM
badddrx7's Avatar
All Spooled Up
The PFC manual says the Check Engine Light will flash if the Injectors are maxed, MAp sensor over 4v or knock sensor over 60. When I turn on my key there is no CEL light any longer. I started my car and lowered the injector warning level down to 10% to see if I could get a CEL and still it didn't flash. My exh overheat light has been removed.
So the question is ( after long searches ) is the manual bullshit or fact ? Does the Rx7 CEL do anything now ?
Old Jun 19, 2005 | 10:55 PM
ORX705's Avatar
Cheese
as the Jap FDs didn't come with CEL the PFC uses the Cat over heat light
Old Jun 20, 2005 | 06:07 PM
badddrx7's Avatar
All Spooled Up
Why in hell mention the CEL in the manual then ?
Tom
Old Jun 20, 2005 | 06:13 PM
neofreak's Avatar
accept no imitations™
My manual said the exhuast over heat light.
Old Jun 20, 2005 | 09:35 PM
ORX705's Avatar
Cheese
same here
Old Jun 21, 2005 | 06:29 PM
RotorJoe's Avatar
Hooray For Boobies!!!
I'm curious about this also. Both my CEL and Exhaust Over Heat light comes on when I turn the key but then they go off as soon as the car starts. I've lowered all my setting thresholds and I still do not get the lights to light up.
I just figured my car was too hacked up and I would have to track that down sooner or later.
Old Jun 21, 2005 | 07:24 PM
badddrx7's Avatar
All Spooled Up
The datalogit manual clearly states the CEL and overheat lights work to tell you of problems. But I have no lights.
Tom
Old Jun 21, 2005 | 09:44 PM
tom94RX-7's Avatar
All those lights such as the CEL light come on and stay on when the key is in the ignition on position, then after you start the car the lights turn out, that is how all cars are, at least all the cars I have, my mx6 does that also, its normal. I have stock ecu. I have been checking my cel codes very often recently because I just fixed a problem after I had a cel code, so now my car doesn't have any cel codes stored in memory, and the cel light stays on until you start the car. I am pretty sure the exhaust over heat light also is on until you start the car, and the other lights such as the ebrake light, etc.
Edit: the "4W ABS", "check" CEL, parking brake, battery, & the overheat exh. light all stay on until you start the car.
Old Jun 22, 2005 | 04:32 AM
RotorJoe's Avatar
I know.
My point was, I'm pretty sure that my CEL and Exhaust Over Heat lights are working correctly. It's just when I adjust the injector and knock warning boxes under the settings one tab with the datalogit, nothing happens.
But after I said that earlier I've noticed my CEL doesn't light up ever. I think the light has been manually turned off.
Old Jun 22, 2005 | 02:08 PM
reza's Avatar
PFC don't lit up CEL at all. I think you are talking about the stock ECU.
Old Jun 23, 2005 | 08:50 AM
TailHappy's Avatar
Addicted to Track
I am convinced that function of the PFC doesn't work. At least it doesn't in my car, and I know the bulbs work, due to starting the car. The way I proved it to myself was to use the datalogit to set the thresholds for the warnings way down to where they should ALWAYS be warning me (such as knock = 10). No lights...
Old Jun 23, 2005 | 03:47 PM
RotorJoe's Avatar
Yep, same here. Which is why I chimed in.
Old Jun 23, 2005 | 04:49 PM
badddrx7's Avatar
All Spooled Up
this is exactly like my car too. With the lack of tech support, the way the manual is written up and what you get for the price...I am beginning to have second thoughts about the PFC and the datalogit..
Tom
Old Oct 9, 2006 | 06:56 PM
dhcernese's Avatar
Dan Cernese
Unhappy useless warning settings?
ditto.
Old Oct 9, 2006 | 08:35 PM
gotparts?'s Avatar
wtf? i didnt know that jdm fd's didnt come with a cel light. i was just thinkin about that today. and i dont have a cat overheat light either. weird?
Old Oct 9, 2006 | 09:16 PM
cewrx7r1's Avatar
Eye In The Sky
Thumbs down
Friggin forum and RoadRunner software and hardware causing multiple posts!
Old Oct 11, 2006 | 10:14 AM
dhcernese's Avatar
Dan Cernese
maybe it's trying?
Originally Posted by dhcernese
ditto.
I noticed the other day that the Datalogit FC-Edit Monitor window's sensor "HWL; Exhaust Temp Over Heat Switch" was flashing.. ..it just occurred to me maybe it was trying to flash the light.
Old Oct 15, 2006 | 11:31 PM
Bob_760's Avatar
How do I made boost?
my lights never come on either, after i wired up the cel light to the exhaust overheat circuit (now they both come on) i tried all sorts of settings to get the lights to come on from knock and duty cycle, no bacon.... I'm hoping that adjusting the settings dosen't work but the default settings do work. Wishfull thinking? Who knows...
Old Oct 25, 2006 | 11:40 AM
Zimbu's Avatar
So if the HWL is flashing, logic would state that it is trying to warn you. Has anyone ever taken a test light to the unused pins to see if maybe one of them is the output for this warning?
Old Nov 9, 2006 | 12:59 PM
Noxlupus's Avatar
Bueller? Bueller? Bueller?
Old Nov 30, 2006 | 07:30 AM
Noxlupus's Avatar
Has anyone had a chance to do this yet? Or does anyone know where I can find the J-Spec Shop Manual so I can see what the Pin (the ones we remove / cut) on J-Spec 7s are for.
rocker1337
16
Sep 6, 2015 11:28 PM
ultradef
Apr 15, 2004 11:14 AM
Kenteth
Mar 19, 2004 05:58 PM
Sprockett
Apr 22, 2003 04:36 PM
