GSL and GSL-SE rear axle compatabilty?
Old Jan 6, 2002 | 07:54 PM
Max7's Avatar
Admitted Sevenaholic
are the 84-85 GSL and GSL-SE axle a compatiable swap. with the wheel bolt pattern being the only difference?
I need to know if I can put 84-85 GSL axles into my GSL-SE housing.
I see that the bearings are the same between the 2.
thanks
Old Jan 8, 2002 | 07:05 AM
Rotorious7's Avatar
i heard you have to change the cage in the punkin also
Old Jan 8, 2002 | 08:55 AM
RX7145's Avatar
-SE with Mods
Bolts right in.
Old Jan 8, 2002 | 11:03 AM
Max7's Avatar
Yea, so does an 86 13B into an GSL :P
Originally posted by PaulAber
Bolts right in.
Old Jan 8, 2002 | 12:52 PM
RX7145's Avatar
-SE with Mods
Yes it is just switch wiring harnesses.
Old Jan 9, 2002 | 09:49 PM
peejay's Avatar
Old [Sch|F]ool
According to the article at Mazspeed, yeah the axles just swap right in...
of course you have to use the appropriate rotors/calipers, but I think you could also just redrill the -SE axles to 4x110, or something close enough so that the lug bolts/studs will go through.
You know how EASY it would be to convert the GSL to -SE brakes? (New rotors all round, calipers all round, axles, and that's it) But then I'd have to give up my 13" stickies
Old Jan 9, 2002 | 10:43 PM
moremazda's Avatar
Gone Race'n
Are the rear caliper hangers the same on the SE? Or is the differance in rotor width made up in the caliper?
Old Jan 10, 2002 | 04:11 PM
spoolin's Avatar
swap
the axel housing is the same and yes the caliper makes up for the difference b/t the vented (SE) and the non-vented (GSL). it is a fairly time consuming process but can be done by any...well, just about anyone. might as well swap the front too for the same bolt pattern..4 nuts on top, 2 bolts on bottom and disconnect the rubber caliper line from the supply and have any wheel you want...as long as its 4x4.5 pattern.
Old Jan 10, 2002 | 04:17 PM
peejay's Avatar
Old [Sch|F]ool
Re: swap
Wow, you take the whole strut out just to change the rotor?
Old Jan 10, 2002 | 04:26 PM
call me!
Pete, call me!! PLEASE!
Mike
The1Sun
Mar 18, 2018 11:08 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
