R2 Tuning
Old Jan 6, 2002 | 01:47 PM
R2 Tuning
Hi all. I own a 1994 Rx7 R2 there is a few things i could do with some help on please.
The first is does anyone know what boost i can run on a stock IC and Turbos? and would it make sence to street port/3mm tip the engine before i start uprateing bits like turbos?
I have a limited cash flow and would be tuning it over a period of time, so i would apreciate it if you would point me in the right direction.
Thanks
Old Jan 6, 2002 | 02:02 PM
Johnny's Avatar
OG
Re: R2 Tuning
Thanks
12 lbs would be about as much as I would run on stock...personally I wouldn't street port unless I was in need of a rebuild or something..and would only go 3mm seals if I had to..because 2mm where out of spec .
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
