Air pump silencer?
Old Jan 5, 2002 | 02:36 PM
Nameless's Avatar
Air pump silencer?
I was just told that some of the older Rx7s have an airpump silencer. I did a little bit of searching and I think it is on the second gen. Am I right? If so, whats it really called, and would anyone have a part number by any chance? A pic maybe?
Share your wisdom with me please, I am not familiar with the 2nd Gens at all. Thanks a lot in advance.
Old Jan 5, 2002 | 06:10 PM
HAILERS's Avatar
HAILERS
Couldn't find it in the manual except a schematic of the SECONDARY AIR INJECTION CONTROL SYSTEM, which shows it and calls it a AIR SILENCER. See this picture http://home.earthlink.net/~burntoast...xports_acv.jpg well that yellow circle in the middle that looks like Africa, down at the tip of Africa you see a one inch in diameter outlet on the acv. There will be a black hose connected to it and the hose will go fwd to a black AIRCHAMBER, and from there another black hose will disappear into the r/h bumper/fwd wheel well. You have to take off a splash guard on the fwd end of the r/h wheel well to access it. Or take the bumper off.
Old Jan 5, 2002 | 06:58 PM
Nameless's Avatar
Thank you so much for your help.
Old Jan 5, 2002 | 08:59 PM
Xentrix's Avatar
Kill Bear
take that stuff out, in my car it made the VDI kick in harder.
Old Jan 5, 2002 | 11:45 PM
NOTA V6's Avatar
My '85 had one. Got rid of it when I got rid of the air pump.
Old Jan 6, 2002 | 03:18 AM
My bestest friend in the whole wide world took his out of his 1990 GXL and it makes a cool *** sound now when he accells... I dont think it really helped much performance wise except he lost a few grams of weight...
Old Jan 6, 2002 | 10:28 AM
NOTA V6's Avatar
It would make a even cooler sound if your friend replaced the cats with presilencers, and lost the air pump all together. And it would give a BIG performance gain and almost 100 lbs. of weight reduction.
Old Jan 6, 2002 | 10:55 AM
so you got ride of that black hose and everything else foward ?
Old Jan 6, 2002 | 11:03 AM
NOTA V6's Avatar
Air pump, ACV, silencer and all attached tubing. I put a rubber beaker stopper in the hole coming out of the air filter that used to lead to the air pump.
Of course I have a GSL-SE, and I've heard that you 2nd gen NA guys need the air pump for your 6PI actuators to work. Is that right?
Old Jan 6, 2002 | 11:06 AM
yeah i need my air pump , can i just leave the airpump in and then remove that hose coming out of the airpump into the silenicer along with the silencer ?
Old Jan 6, 2002 | 07:47 PM
NOTA V6's Avatar
Yep. It's just a muffler so you don't hear the hissing/whooshing sound of the air pump overflow.
Old Jan 7, 2002 | 03:28 PM
MaxRX7's Avatar
hambre y sueño
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
