PTP"dual" pump setup GOT FUEL?
Old Jun 4, 2005 | 11:47 PM
tearbo2's Avatar
hey 3rd gen and 2nd gen owners check out our new dual pump setup,comes complete the way you see it polished lid,2 walbro pumps, hoses,clamps,a/n fitings
-8 feed w/ -6 return. this is a direct drop in unit, just add your fuel Lines!!!!!
Attached Thumbnails PTP"dual" pump setup GOT FUEL?-dsc00431.jpg   PTP"dual" pump setup GOT FUEL?-dsc00432.jpg   PTP"dual" pump setup GOT FUEL?-dsc00433.jpg
Old Jun 5, 2005 | 06:42 AM
88fc3sw/HX83's Avatar
Wow, that's a SWEET setup....how much and how do I order it?
Old Jun 5, 2005 | 09:43 AM
kabooski's Avatar
Laying Down Rotary Law
WOW sweeeet!
If I didn't already ghetto rig a duel walbro setup on my car
I would be all over this
Old Jun 5, 2005 | 12:32 PM
tearbo2's Avatar
[QUOTE=88fc3sw/HX83]Wow, that's a SWEET setup....how much and how do I order it? [/QU
the dual pump setup retails for $600.00
I belive (don't hold me on this) he'll let forum members have it for $500.00!!!!!
you and anyone can contact HASS @ (512)490-6494 to order
Old Jun 5, 2005 | 01:16 PM
Zero R's Avatar
Just in time to die
Is this still giving the same crappy pickup issues?? My guess is it is unless modified in some way. I've made the same exact setup before, all aluminum etc. If the pickup isn't addressed all the pumps in the world are not going to help. Not bashing anyone just informing.
Old Jun 5, 2005 | 01:41 PM
tearbo2's Avatar
no bashin taken but to answer your concern. when we designed the unit we knew that was a problem w the diy's, we addresed the issue by removing a 3rd gen (and 2nd gen) tank. cut it in half to see where the pumps were going to PLAY and found a good and happy place for them. so there is NO crappy pick up issues w/ the PTP setup.this is the same setup on my car,and my car lays down 560 whp w/ no fuel delivery issues.
Old Jun 5, 2005 | 03:11 PM
BDC's Avatar
BDC
BDC Motorsports
Very slick, Lee.
B
Old Jun 5, 2005 | 03:46 PM
tearbo2's Avatar
Originally Posted by BDC
Very slick, Lee.
B
thanks brian!!! did I mention the aluminium bracket that holds the pumps has an inner rubber o ring for reduced noise the biggest advantage to the dual setup is the pumps always stay cool!!!!
Old Jun 5, 2005 | 04:22 PM
Zero R's Avatar
Just in time to die
Good, and it is nice to see someone not take it as bashing for once. Stock location sucks both for highHP straight line and esp. for the turns. Glad to see some one thought it through. I figured you had. Just couldn't tell by the pic.
Old Jun 13, 2005 | 11:29 PM
Carl Byck's Avatar
Mad Man
Looks like a solid piece, but it also looks like it sits in the stock location. How did you fix the P/U problem? Also is the return is right next to the P/U, thought I'd ask since you are so open minded about questions. The Supra guys are doing these in a two, and a three pump configuration. Dual rear corner P/U or a surge tank/weld in sump are the only solutions I have seen that worked well. Nice workmanship none the less. Carl
Old Jun 14, 2005 | 01:03 AM
BDC's Avatar
BDC
BDC Motorsports
Rock and roll, Lee. Terrific idea!!!
I am about to switch over to a dual Walbro GSS342 pump system setup here in the next couple of weeks. Once I get mine done, I'll post up some pictures of it all. It was over $600 in parts, hose, and fittings!!
B
Old Jun 14, 2005 | 06:05 AM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
How much sans pumps, lines, fittings and not polished?
Old Jun 20, 2005 | 01:12 PM
Jonptp's Avatar
Hey guys I am a little new to the forum my name is Jon from Protech Performance
Anyway I am trying to get you guys some pictures of the assembly inside the tank since we cut a hole in the tank to build the sump. I'll try to get you guys a picture of both the stock sump and ours. We designed the sump from the stock modified sump we have been using for almost 4 years now. We have never had a pickup problem so I dont expect to see any problems from our new design. We even have 2 customers that road race using our setup and they dont seem to have any problems. If you guys have any other questions though feel free to ask me or email me.
Thanks
Jon
Protech Performance
www.ptpmotorsports.com
512-834-8771 tel
512-834-8772 fax
Old Jun 27, 2005 | 11:44 PM
hIGGI's Avatar
stock TII fuel tank cut pics :
http://rx7cz.net/photos/workshop124/IMG_4766.JPG
http://rx7cz.net/photos/workshop124/IMG_4767.JPG
http://rx7cz.net/photos/workshop124/IMG_4768.JPG
http://rx7cz.net/photos/workshop124/IMG_4769.JPG
http://rx7cz.net/photos/workshop124/IMG_4770.JPG
http://rx7cz.net/photos/workshop124/IMG_4771.JPG
http://rx7cz.net/photos/workshop124/IMG_4772.JPG
Old Jul 4, 2005 | 06:48 PM
R.P.M.'s Avatar
Likes to swear....alot
Hey that looks nice!!
Will you sell the unit without the Walbro fuel pumps? and if so, what would that cost?
Old Jul 4, 2005 | 08:09 PM
Railgun's Avatar
I won't let go
$400 if you can believe that. Where 2 pumps and the lines/fittings = $200 is beyond me.
Old Jul 4, 2005 | 08:22 PM
R.P.M.'s Avatar
Ok screw that, I'll just make my own i guess.
Old Jul 5, 2005 | 08:17 AM
rx7tt95's Avatar
Photo Diety
Generally speaking, each Walbro is about $110. I purchased one slightly below that not too long ago and you may be able to find deals on E-Bay. Most fittings run what, $15 a pop? So $200 comes up pretty quick I'd say.
Old Jul 5, 2005 | 08:20 AM
kabooski's Avatar
That Y fitting is not cheap like a regular AN fitting
then add the others it adds up
Old Jul 5, 2005 | 08:29 PM
tearbo2's Avatar
Thanks, we will sell the FC setup and the FD setup for $300.00 and the price is $550.00 w/ pumps.
Old Jul 5, 2005 | 09:23 PM
R.P.M.'s Avatar
That $300 includes all the brackets and AN fittings?.....because I can get Walbro's.......
Old Jul 5, 2005 | 09:33 PM
tearbo2's Avatar
YES, has the brackets and an fittings, jus like the pic w/ out the pumps.
polished included. just add the pumps.
Old Jul 5, 2005 | 09:47 PM
Railgun's Avatar
I won't let go
Ooo...you knocked $100 off? Ok...then how much...again...w/o the fittings and NOT polished?
Old Jul 5, 2005 | 09:52 PM
kabooski's Avatar
your going to need the fittings and Push lock hose
that comes with the kit
since the bracket was designed for use of those particular fittings
My duel pump set up
came out UGLY
and I have gas smell lol
even after adding ton of silicon
It was a major pain in the as
trying to get the pumps go thru the opening
since the hose clamps make it very very tight
and now my fuel level
isnt working right
I'm going to replace my ghetto setup
with the PTP Setup soon
Old Jul 5, 2005 | 10:45 PM
tearbo2's Avatar
kabooski answered this one. thanks kabooski.
