vacuum routing S4
Old Jun 4, 2005 | 03:21 PM
Houstonderk's Avatar
My girl
vacuum routing S4
I have an 88 n/a that i am turboing and switched all the Tii things on the n/a block with all the emissions tooken off and everything blocked. I have the vacuum line from the bov and pressure sensor going on the UIM nipple and two others, one coming from between the two blocked oil injectors and one coming off by the subzero thing. do i run the one by the subzero thing behind the throttle body and the other one to the fuel rail?
Old Jun 4, 2005 | 07:00 PM
My girl
also is there anything special about the green boost soloniod or could any soloniod that looks like it work?
Old Jun 4, 2005 | 07:19 PM
My girl
Okay i just found it out. Run the line from the one that points to the firwall and that goes to the fuel pressure regulator at the end of the secondary rail and the one that is between the injectors to the TB. It says that i don't need that soloniod thing if its only a S5 though so i still need it for an S4?
ls1swap
Jun 3, 2024 03:25 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
scissorhands
Oct 8, 2015 01:17 PM
