90 vert vs 2002 ford focus :[
Old Jun 4, 2005 | 02:08 PM
frigidmonkey's Avatar
rotor withdrawal
how much difference do the 5/6 ports make? I drove my car home today, no 5/6 ports because I had to drive it home with no exhaust. I was wondering because coming off a light, up to about 70, I had it floored, shifting at redline, my gf driving her focus stayed right on me, and she said she wasnt anywhere near flooring it.
Does this sound about right? Would the 5/6 ports make that much difference, or is there something else wrong that I should look for. I mean, running with all ports open, a stock focus zts shouldnt be able to match my acceleration, should it?
Old Jun 4, 2005 | 02:09 PM
d0 Luck's Avatar
raysspl.com
6 ports don't really have good top end power on them compared to 4 ports.
Old Jun 4, 2005 | 02:17 PM
rotor withdrawal
what about off the line , up to 70
Old Jun 4, 2005 | 03:23 PM
homebrewer's Avatar
Don't waste your time trying to fig\ure out what is faster than a vert. I suspect that even a 25cc moped would beat a vert 0 to 30 mph.
The vert's strengths is that it looks good and handles pretty good too.
Old Jun 4, 2005 | 03:52 PM
rotor withdrawal
so probalby wasting my time adding performance parts to it?
Old Jun 4, 2005 | 03:55 PM
JTP's Avatar
JTP
I would just swap in a 13BT(turbo motor) and then have the looks of the vert and the ***** of a turbo.... look around, you will find info on it and alot of ppl who have done it.
Old Jun 4, 2005 | 04:02 PM
ViperBart's Avatar
Compression King
... to answer your first question.... the ports atcivate around 3500 rpm and add about 25 hp to the top end
Old Jun 4, 2005 | 04:05 PM
ViperKillerWannabe's Avatar
Resident Moonwalker
Exhaust doesn't affect the aux ports on an S5. They're activated by the airpump instead of exhaust backpressure.
Old Jun 4, 2005 | 04:16 PM
ViperBart's Avatar
Compression King
my mistake
Old Jun 4, 2005 | 06:35 PM
Mordachai's Avatar
_
Yeah that's one way to do it, but by the time you've added the hulking TII motor and the tranny and all, you're adding a bunch of weight , not to mention time and costs. You can take the same(or less) money and time and just do the more basic things to your n/a.
There are also a few threads about it.
Here's one that might change your mind on the TII swap!!!!
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/what-i-have-been-doing-gone-back-non-turbo-260972/
There's a bunch of other threads to be found, just search
|M|
Old Jun 4, 2005 | 06:42 PM
ViperDude152's Avatar
Rotary Power Information
^ how much more weight are you adding? intercooler and turbo? the engine is the same...
Old Jun 4, 2005 | 06:58 PM
dregg100's Avatar
^ he would need to put a differant engine in it. it currently has a 13b he needs a 13bt. unless he wants to do a 6 port turbo setup. about weight, correct me if i'm wrong but i think it's like 200 lbs added.
Old Jun 4, 2005 | 08:55 PM
rotor withdrawal
so the tube coming off the exhaust isnt for the 5/6 port actuators?
Old Jun 5, 2005 | 10:43 AM
Jager's Avatar
Tear you apart
Arg, a Turbo engine, transmission, and driveline is heavier because it is a series of stronger components, maybe 125-175lbs. And what you trade off for power is quite big. Going from 160hp to 200hp helps, ontop of that, you add a FCD, intake, exhaust, and a MB controller, you're pushing 220hp-250hp. And that only would cost a few hundred bucks (CS exhaust = 500, custom intake = 50, FCD = build your own, MB controller = ebay for 25.
The first question to anyone looking to make more hp is, how much are you willing to spend?
Old Jun 5, 2005 | 10:27 PM
rotor withdrawal
2 grand
Old Jun 5, 2005 | 10:39 PM
Resident Moonwalker
That's the split air pipe. The air pump blows into that.
Old Jun 5, 2005 | 10:42 PM
jhammons01's Avatar
Carter 2.0
Here is the sad point. Without an exhaust you'll be getting MORE low end and a nice power curve throughout. You have the ultimate free flowing exhaust. The next wtep would be to mod the intake somehow. Maybe then you amy be a challenge to those pesky Focai.
I speak from experience as a Focus and a Altima Kicked my verts (with an auto tranny) *** just last night.
Old Jun 6, 2005 | 11:10 AM
rotor withdrawal
I can't have that going on. A focus is not that impressive. So, as soon as I fix the exhaust and the radiator I'm going to either sell or trade off the vert. maybe find a hard top FC or who knows, maybe even go back to FB
Old Jun 6, 2005 | 11:44 AM
ultradef's Avatar
Ready to Rock
If you're looking for a fast car, why did you buy an N/A? What did you expect from a car that weighs 3000 lbs. and had 160 hp from the factory (and possibly considerably less now depending on mileage/wear). A Focus weighs 2600 lbs. and has 130 hp and is much newer, so yes it may be faster than a stock vert. Verts (and N/A's in general) not known for their straight line speed (in stock form).
Old Jun 6, 2005 | 01:42 PM
rotor withdrawal
dude, give me a break, what did I expect? I expected a "sports car" to act like one, not be one of the slowest things on the road. A focus is newer yes, but they are not fast by any means, so it was a surprise that a "sports car" running full throttle had no chance at all.
and why did I buy an N/A... because I found a 90 vert with less than 90 K on it, a perfect top, near perfect interior, near perfect body, NO rust, and needing VERY little work for 200 bucks , seemed like a bit hard to pass up. Now that I know how slow it is, I'll do that little bit of work that it needs and sell it or trade it and get me something faster
Old Jun 6, 2005 | 02:47 PM
ultradef's Avatar
Ready to Rock
I think you're confusing "fast" with "fast in a straight line". The FC3C is a sports car and does "act like one"...if you drive it like one. Take your FC and the Focus through some twisties and see who's faster...or go buy a Mustang and drive in a straight line.
Old Jun 6, 2005 | 04:52 PM
7romanstatesmen's Avatar
coolant leak that kills
r&t tested the zts, and it hit 60 in 9.3 seconds, which i believe is pretty close to what the vert did when they tested it way back when. a friend of mine has one, and when she drives it, it's pretty fast (relatively speaking, of course). don't worry about it.
Old Jun 6, 2005 | 05:07 PM
KillaKitiie's Avatar
Bongolio
I raced a zx3 foci and got my *** beat he walked me harder than my friends crx pushing 10lbs!...i do not know what it had but i wonder how much faster it is than a stock zx3.
Old Jun 6, 2005 | 10:13 PM
rotor withdrawal
hmm, mustang, I dont really like the style, but dont mind their performance. I'll just keep cleaning up the vert and try to trade it for something lighter, and if I can't find anyone interested, I'll put a 302 in it
Old Jun 6, 2005 | 11:43 PM
jhammons01's Avatar
Carter 2.0
Hey, Frigidmonkey, you sound just like that guy that tried to race a top fuel rail dragster at Sears point the other day. All he did was complain.........only you two are opposites!!!
YOU should have the top fuel and let the guy at Sears point have your 7
Note: the guy with the top fuel dragster at Sears Point is completely fictional and was made up to prove a point.
