Just installed a termostat and the water boils
Old Jun 2, 2005 | 12:28 AM
.Zero's Avatar
Well the car started to over heat when the weather here got around 90+ degrees. my mechanic said that perhaps a new termostat would help since it's probably the original.
now the car runs fine. the temp guage goes above what the normal temp guage would go and stays as if that is the new normal operating water temp. When i get done driving it i pop the hood (i seem to do that every 15 mintues) to check it all out and the water overflow is... overflowing and bubbles are coming out as if the water is boiling. there is hardly any collant in the lines when I open the radiator cap.
Old Jun 2, 2005 | 12:30 AM
jhammons01's Avatar
Carter 2.0
Blown coolant seals. Smell for an Exhaust smell in the radiator
Old Jun 2, 2005 | 06:32 AM
RETed's Avatar
1) Verify the radiator is not clogged.
2) Get a pressure test to see if the cooling system is leaking.
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
rotor_veux
Aug 31, 2015 07:49 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
