just replaced engine, running too rich at idle
Old Jan 4, 2002 | 08:33 PM
oakridgerx7's Avatar
I just replaced the engine in my car, and the engine runs so rich at idle, that it puffs out smoke, and literally burns your eyes from the unburnt fuel, could a vacuum leak cause this? I have not driven it yet so I dont know how it runs. Could a vacuum leak cause this? maybe a bad fuel injector? any ideas? I had the motor street ported and it has a downpipe. I heard that with a street port that you needed to either advance or retard the timing. could this be the cause?
Old Jan 4, 2002 | 09:17 PM
Brent Dalton's Avatar
Sua Sponte
hey man, don't know the answer to your question, but just wanted to say congrats on getting the car back running, hopefully it will stay this way for more then 5 minutes *crossing fingers*. Anyhow, congrats and next time I'm going to knoxville I'll shoot you an email and we'll check out FD's. Later
Memphis
Old Jan 4, 2002 | 09:29 PM
JoeD's Avatar
what are your mods?? if you are running a dp and streetport on the stock ECU, you should not be running rich.
Old Jan 4, 2002 | 09:32 PM
the guy who installed the engine seems to think that a vacuum line popped off somewhere, he said he could hear something sucking air. yes i have a stock ecu and a downpipe and street port.
Old Jan 4, 2002 | 10:30 PM
Conv.WS6's Avatar
It's odd that if the guy zip tied all the lines that one slipped off. But stranger things have happened. Keep us posted with what was the fix. Good luck.
Old Jan 4, 2002 | 10:57 PM
gago's Avatar
My car does the same thing. It burns so rich my eyes hurt right away.
But my car has an exhaust leak between the manifold and the turbo. Theory is, the o2 sensor is reading the incoming air and then compensates for it. As soon as I change the gasket I'll let you know.
Hope this helps
Old Jan 5, 2002 | 08:27 AM
any ideas guys, I need your help
Old Jan 5, 2002 | 12:32 PM
an_juan's Avatar
if the air pump is not on, then the exhaust becomes saturated with unburnt fuel. Make sure your air pump is running because it helps the at clean up the unburnt fuel.....that's if you still have the main cat.
Old Jan 5, 2002 | 06:10 PM
anyone else? cmon rotary nuts
Kyo
Apr 13, 2019 09:24 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
