Stereo Help
Old May 30, 2005 | 09:55 PM
Tournapart's Avatar
RIP Icemark
Angry Stereo Help
i just got a new alpine stereo, dash kit, and smart cable wiring harness today. got the dash kit together, soldered the wires from the smart cable (mazda harness-into-universal) to the wiring harness for the deck. turn it on, lights up great. no sound. i cant figure out whats wrong. i dont care about the antenna i hate the radio but i would like some sound damn it. its really frusterating. i did a search but didnt find the info i was looking for. i commute every day and need some kind of sound to stay sane. any help is appreciated. also i did go over the wires and found that there are more wires going in to the mazda harness than coming out of the smart cable, and i am aware of the factory amp and was wondering how to bypass it. its a 91 vert, that came stock with the pioneer amp and the combo CD/Tape deck.
thank you
Old May 30, 2005 | 10:36 PM
Tournapart's Avatar
RIP Icemark
sorry. i searched again and found the problem. i had the illumination wires soldered to some speaker wires. i chopped the wires and the front speakers work. any way to get the factory 3.5inch sub whatevers behind the seats to work? its not much bass i know, but more than the front components have. thanks
Old May 30, 2005 | 10:40 PM
TurboSE's Avatar
does the new harness have a (blue remote wire?) Some cars have a factory amplifier or(amps) for the rear subs..............Do U have speakers in the headrests? I'll check on the wiring color code and let ya know.....
Old May 30, 2005 | 10:57 PM
TurboSE's Avatar
Radio 12v
blue/red
radio harness
Radio Ground (chassis)
Radio Ignition blue/white + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on white radio harness
Power Antenna blue/yellow - radio harness
LF Speaker +/- lt. green/red - lt green/black +,- radio harness
RF Speaker +/- lt. green - lt. green/yellow +,- radio harness
LR Speaker +/- brown/white - brown +,- radio harness
RR Speaker +/- blue/orange - blue +,- radio harness
Old May 31, 2005 | 01:29 AM
Tournapart's Avatar
RIP Icemark
is there still another amp even if i pulled the whole stock stereo and the pioneer amp connected to it? if there is ill try to hook up the remote wire. and yes i have the head rest speakers, but they never worked.
Old May 31, 2005 | 03:18 AM
Curtisleeyoung's Avatar
thank you
Ok here is where your at, your 91 convert if it still has it's orignal seats should have speakers in the headrest. As you already know the factory amp powers these speakers and the rest of the speakers in the car as well, to use these factlry speaker wire plugs (the stock wire that connects to the speaker) you have to use the stock amp. If you want to by pass the amp then you will have to run your own wires to the speakers. It's not a bad idea to to this anyway as the stock wiring can get pretty thin at times, your own run 14ga wire will sound wonderful.
<signature removed for size violation- images are limited to the size of 6 lines- fix your signature
Old May 31, 2005 | 06:33 PM
88sunlover's Avatar
World Slurpee Capital
Unhappy
Any thoughts on what you can do for rear sound for an 88 vert?
I'm pondering finding the parts to do the headrest speakers but it seems this is going to be painful
TeamRuffRacing
Sep 30, 2015 08:13 PM
betes
Sep 27, 2015 08:25 AM
Captain Hook
Sep 22, 2015 01:12 PM
