champagne bubbles
Old Jan 4, 2002 | 12:33 AM
asianturbo's Avatar
champagne bubbles
I just checked my coolant and started the car up and noticed that tiny little bubbles are coming up, but not a lot just a few, does this mean my coolant seals are going? And how long do I have till my engine goes? This motor only has 27K miles on it and how is that possible?
Old Jan 4, 2002 | 02:10 AM
JspecFD's Avatar
Yep, that could be the O-rings. Watch the coolant levels and see if any coolant is getting consumed. Mileage isn't really a direct factor. Its more a question of if the car ever overheated at all. Even if the car overheated just once, it could warp them and a rebuild is the only way to fix it. From others, what I've noticed is that the problem just keeps getting worse and worse over time.
Old Jan 4, 2002 | 12:49 PM
dis1's Avatar
www.silverbulletrx7.com
JspecFD is right. Actually what you did is one of the better ways to test if you have a coolant seal problem. It looks like you do. IMHO a quality aftermarket water temp gauge is very important and can easily save a motor. You may have over heated and never noticed. The stock gauge isn't worth the space it takes up.
Old Jan 4, 2002 | 12:56 PM
rx7eaven's Avatar
Yeah, the aftermarket water temp guage is very important. I like mine anyways Sorry to hear about the motor though
Old Jan 4, 2002 | 01:24 PM
I am not sure you should condem the engine yet.
I believe small bubbles are normal. It is when you see bigger bubbles, and frequent ones.
Also, how did you check this? Start the car, and open the T-stat housing?
You might want to search the forums for similar posts.
Later,
Patrick
Old Jan 4, 2002 | 09:25 PM
asianturbo's Avatar
yeah thanks for the replys, i checked the coolant and it is still full and when I started it again this morning and their was no bubbles or from what I could see, and there wasn't a lot of smoke, but i think it smelled like coolant or maybe water I dunno or wasn't to sure.
Andrew7dg
Aug 6, 2017 01:41 PM
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
Frisky Arab
Sep 4, 2015 06:17 PM
