Haltech MSD with Haltec E6k
Old May 19, 2005 | 01:01 PM
adictd2b00st's Avatar
boost > *
MSD with Haltec E6k
ok i'll admit i'm a lil new to all this ignition stuff on rotaries, so i'm a lil lost..... what setups are u guys running that have been proven to work well on with a single turbo? this is on a 13bREW btw.
*edit* general consensus seems to be 6a, but what else do i need cause thats the part that i don't understand
Old May 19, 2005 | 02:43 PM
C. Ludwig's Avatar
www.lms-efi.com
On a recent build we did with a E6X 13BT, PT61 single, and 2nd gen coils we got ignition breakup at anything over 15psi. Threw in a Crane Hi-6 (MSD 6A equivalent) and the problems disappeared. Ignition is now strong to 20psi.
Old May 19, 2005 | 05:56 PM
Project84's Avatar
Open up! Search Warrant!
If I remember correctly, the difference between MSD 6a and the MSD 6 is that the 6a has a RPM limiter and the 6 doesn't. The E6K has a programmable limiter, so I don't see the need for an ignition system that has one built in.
Old May 19, 2005 | 09:30 PM
dubulup's Avatar
development
I'm running with a 6A on leading.
Old May 20, 2005 | 01:07 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
I havent had an X with MSD install, but i haved had E6S and E6K with a trio of MSD 6A's and the only weak link was factor plugs, that after 13psi died and missfired a lot, other than that, MSDs work wonderfully.
PS. Its 6A and 6AL, the L having the rev limiter built in.
Old May 20, 2005 | 08:23 AM
boost > *
so i can just get a 6A and be done with it? i don't need to get the coils as well?
Old May 20, 2005 | 12:13 PM
C. Ludwig's Avatar
www.lms-efi.com
The 6A is the standard, entry level ignition amp. The 6AL has the limiter. Yes, adictd2b00st, you can simply add a 6A to the coil setup you are currently using. However good coils can also make the difference between a good spark and a weak one. The MSD will help produce the best spark from whatever coil you are using.
Old May 20, 2005 | 12:52 PM
EFI Tech Wannabe
It should also be noted that the factory FC coil packs are very capable ones, and when paired either with an ignition amplifier or with properly tweaked settings on the Haltech you can get great spark from it. And unless they are abslutely fried/ancient/beat up/turned to mush i would stick with them, or you will be runing over 30psi of boost, they are more than enough.
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
