Vacume Hose routing on 94 touring
Old Jan 3, 2002 | 11:14 AM
1984GSLSE's Avatar
I am in the middle of replacing putting my turbo piping back together and repacing my vacume hoses with silicon and I got lost somewhere...
I'm having dificulty reading the hose routing in the manual(F-10) and was wondering if someone could help. There is a nipple between where the Charge Relief valve connects to the turbo piping and the Actuator (Charge Control) that is not shown on the diagram. Where does it connect to????
Old Jan 3, 2002 | 02:27 PM
rxrotary2_7's Avatar
hope this helps
Old Jan 3, 2002 | 07:40 PM
nrolfes1's Avatar
hey 1984 could you be more specific about where the nipple is exactly (which pipe it taps into?)
Old Jan 3, 2002 | 07:43 PM
rynberg's Avatar
check out this link for a color coded version of the above piping diagram:
http://www.zeroglabs.com/rx7/images/...oses.color.jpg
Old Jan 3, 2002 | 09:58 PM
Wargasm's Avatar
Weird Cat Man
Yeah that zeroglabs one kicks ***.
B
(yes, I made it... so I'm a little biased)
Old Jan 3, 2002 | 10:39 PM
Flybye's Avatar
It's never fast enough...
The charge control actuator is a 2 sided actuator. Boost must be of equal amount on both sides for this actuator to open up and allow boost from the 2nd and 1st turbo to mix.
This actuator WILL have 2 nipples. One connects directly to the Y-pipe coming from the 2nd turbo, and the other nipple attaches to the charge control solenoid.
Old Jan 3, 2002 | 10:54 PM
kevinmfaust's Avatar
The nipple you are talking about goes straight up about 2 inches to the actuator. The actuator has 2 hoses on it.
Kevin
Old Jan 4, 2002 | 05:01 PM
1984GSLSE's Avatar
?? Help on vacume hose
The nipple I'm am talking about is not in the above diagram, but if it was, would be directly below the 'Charge Relief Valve' in the above diagram by one of the bolts that attaches the 'Actuator (CHARGE CONTROL) and comes up and then 90's pointing toward the passager side of the car.
Old Jan 4, 2002 | 05:23 PM
1984GSLSE's Avatar
[IMG]F:\DCIM\100DC240\dcp_2706.jpg[/IMG]
Here's a picture
Old Jan 4, 2002 | 08:53 PM
1984GSLSE's Avatar
Boy do I feel stupid........
I think I just figured it out........ What I am lookng at is not a vacuum hose nipple, but a allen headed screw.
Thanks for all the help, especially the color coded hose diagram.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
scissorhands
Oct 8, 2015 01:17 PM
