Are Tender Springs Necessary?
Old May 14, 2005 | 09:32 PM
caredden's Avatar
Super Moderator
Veteran: Marine Corp
Question Are Tender Springs Necessary?
If coilovers have independent adjustable spring perches, and are ride height adjustable, are tender springs necessary?
Old May 14, 2005 | 10:22 PM
rynberg's Avatar
No.
Old May 16, 2005 | 07:54 PM
maxcooper's Avatar
WWFSMD
I'll second that. No.
-Max
Old May 16, 2005 | 08:08 PM
jgrewe's Avatar
GET OFF MY LAWN
I'll say, it depends. If your springs give you the rate you are looking for, the ride height you want, and fill the area between the perches when your shocks are fully extended then no. If your springs float around when the shock is extended then they might be useful. You can also limit the droop of the suspension instead. Usually with so much adjustment available you can work around a short spring without them.
Old May 16, 2005 | 08:33 PM
rynberg's Avatar
He is talking about coilovers with INDEPENDENT spring perches and ride height. The situations you are talking about do not exist with coilovers of this type. Your situation occurs with the typical entry-level coilovers that use the spring perch to control ride height.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
inMotion719
Sep 28, 2015 03:09 PM
