Sponsored by: CARiD
13B gslse transmission
Old May 12, 2005 | 06:56 AM
GLC13B's Avatar
I'm running a 12A transmission w/ a 13B 6port engine. I was wondering if a gslse transmission would be better than my 12A trans ! How much could i expect to pay for a transmission like this ?
Old May 14, 2005 | 12:39 PM
ArmyOfOne's Avatar
Bridge Port Freak
I am running the same setup.
I have had much better results with the GSL-SE transmission.
12A tranny sheared output shaft
'86 tranny dead synchros
GSL-SE stuck in gear (this was because of worn shift forks!) Just rebuild it and it will be tons of fun!!!
Good luck
Old May 15, 2005 | 12:03 PM
GLC13B's Avatar
I've heard you have had alot of good progress with your car. It must be nice to have a pioneer like Judge Ito close by for technical support ! What year clutch kit are you using with your 6 port and gsl-se transmission ?
Old May 15, 2005 | 04:44 PM
peejay's Avatar
Old [Sch|F]ool
The -SE trans has a taller (more useless) 5th gear.
Otherwise the trannies are identical internally. No advantage.
Old May 15, 2005 | 06:54 PM
puntorotary's Avatar
Rotary Mechanic
its not worth the hassle to swap,cause the change is so miniscule you wont even notice the change.
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
