holy crap saw a stock turbo fd dyno 376hp!
Old May 6, 2005 | 07:35 PM
Bluem's Avatar
Concept Motorsports
so ive read about this fd that runs 10.98 1/4 mile on stock turbos and mickey thompson , the car dynoed 376hp on 17psi. boost in front of my eyes siguel racing did the tunning
only mod to the turbo system is a F.M.I.C. and an external waste gate the rest is the mazda oem ,all bolt ons and a "secret port" wich is probably an extended street port
the ecu is a micro tech
Old May 6, 2005 | 07:50 PM
MR_Rick's Avatar
Planning my come back
Es de Puerto Rico, que mas tu esperas en la isla donde saben hacer motores rotativos correr?
Old May 6, 2005 | 08:00 PM
how does the external wastegate work? Weld onto the exhaust manifold?
Old May 6, 2005 | 08:26 PM
dgeesaman's Avatar
What kind of dyno was it?
Old May 6, 2005 | 08:31 PM
KaiFD3S's Avatar
SINFUL7
external wastegate on the stock turbos? Please explain and do you have any pics of this setup?
Old May 6, 2005 | 08:58 PM
wReX's Avatar
Does not drive a WRX!!!
Yes more info about the wastegate please. Did he weld the internal shut?
376 is a good number, but not anything that outrageous. I put down 367rwhp @ 16psi on the stock twins. (Mustang dyno) Tried to run 18psi but the boost just wouldn't hold correctly with the stock (non-ported) wastegate.
Old May 6, 2005 | 10:37 PM
Bluem's Avatar
Concept Motorsports
wow, i just talked to my friend hes still ther with his car and they just put down 397 hp
i dont know how the wastegate works i havent seen the car on a lift but ireally whant to now
Old May 6, 2005 | 10:55 PM
FDNewbie's Avatar
Sponsor
Ditto.
That isn't on stock internals, is it?
Old May 7, 2005 | 04:25 AM
t-von's Avatar
Rotor Head Extreme
I doubt everything else is OEM. Your not going to put down that kind of power on a OEM fuel system.
Old May 7, 2005 | 05:04 AM
TT_Rex_7's Avatar
-Alex
Edit: Nvm, you was talking about the turbos. I thought you was talking about the engine.
Old May 7, 2005 | 11:17 AM
FDNewbie's Avatar
Sponsor
Originally Posted by TT_Rex_7
-Alex
Alex, actually I was talking about the engine. Stock port? Stock rotors?
Old May 7, 2005 | 01:30 PM
Hyperite's Avatar
Vagina Junction
Ding ding ding.
Old May 7, 2005 | 02:44 PM
moehler's Avatar
I think that he meant the turbo system only was oem (minus the FMIC and the wastegate), not the entire engine.
Old May 7, 2005 | 02:54 PM
sdminus's Avatar
Cant be bothered anymore
WOW. Im intrigued. Benn wondering how much they would flow. Any more info on this car.
SCott
Old May 7, 2005 | 06:34 PM
matty's Avatar
is this corrected or uncorrected?
thats some good power. dont know why people are afraid to run some boost.
Old May 7, 2005 | 06:50 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Because the shafts are the size of a toothpick and bend VERY easy. They will hold up for a little while then go to crap. They are ok for drag racing, you'll get quiet a few runs out of them but you drive that kind of boost a lot and they wont make it. John used to run a external wg and said it didnt make any difference so he took it off. I dont think the problem is the wg.
So far I havent seen this guy put down any numbers that havent been done before.
Stephen
Old May 7, 2005 | 06:58 PM
matty's Avatar
Stephen
well, i agree. but u dont need 400rwhp all the time either. just when at the strip or if u want to put a loud mouth friend in his place. so i say turn up the boost!
Old May 7, 2005 | 11:10 PM
DGnizer's Avatar
so when are we going to see proof on this and more info on the car' set-up?
Old May 8, 2005 | 02:06 AM
Mr rx-7 tt's Avatar
rotary sensei
A motor I built dynoed 374 rwhp on the stockers at 15 psi recently. I have also seen higher.
Old May 8, 2005 | 02:09 AM
Mr rx-7 tt's Avatar
rotary sensei
Stephen
Sure they won't... LOL
dkwasherexd
May 27, 2017 04:51 AM
Turblown
Aug 14, 2015 04:48 PM
Clacor
Aug 14, 2015 09:17 AM
