oil temp normal reading anyone?
Old Jan 1, 2002 | 08:58 PM
puma's Avatar
canadian monster
anyone can tell me this? i have done a search but all i can find is the oil pressure, anyone knows the temp to know which guage i should get?
thanks a lot
puma
Old Jan 2, 2002 | 10:40 PM
puma's Avatar
canadian monster
c'mon there must be someone with an oil temp guage in here
Old Jan 3, 2002 | 12:48 PM
Scorpio's Avatar
My HKS gauge (metric) will get up to 125C max on a hot summer day in traffic. Normal cruising on a hot day and it's around 100-110C.
In the winter, it is lower, sometimes in the low 80s (celsius) but probably averages 95C. This is with 10w-30 Penzoil.
I have an R2 so I have dual oil coolers. The sensor for my oil temp gauge is in the oil pan. Shifting to a higher gear will bring the temp down 5-10 degrees fairly quickly on the flats when just cruising.
A guy I knew with an R1 always seemed to have oil temps about 10 degrees lower than mine...not sure why tho.
Hope this info helps...
Old Jan 3, 2002 | 03:12 PM
puma's Avatar
canadian monster
all right so what's the range on your guage?
thanks
puma
Old Jan 3, 2002 | 03:18 PM
Scorpio's Avatar
It goes from 40-150C. Here's a pic...it's the one on the right.
Old Jan 3, 2002 | 04:45 PM
puma's Avatar
canadian monster
great thanks a lot
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
The1Sun
Mar 18, 2018 11:08 PM
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
