Microtech microtech 550cc and 1600cc setup
Old Apr 23, 2005 | 10:29 PM
1sgen's Avatar
583 rwhp 1st gen
i dont know what happened to my post but anyway here it is:
iam having a problem setting up my 1600 cc to run properly.
i have 550 on the primeries and trying to set up the 1600 . the staging is 3000rpm and 0" vacuum and every time they come on the engine feels it shuts down and it starts back firing through the exhaust
i tried the staging % at 75 , 85 , 95 and 99% and no difference at all.
keep in mind the engine runs excellent with 1000cc in the secondaries but i need the1600 cuz 1000cc are maxing out.
i thought maybe the 1600 are dumping too much gas so i went to the rpmwot map and tried taking off 10,20,30,35% at 3000 and 3500 rpm just to try and still the same , every time it gets to 3000 rpm when the sec. injectors kick in the engine does the same.
need help guys
thanks
sam
Old Apr 24, 2005 | 06:54 AM
Infini IV's Avatar
Microtech Tuning!
When you switched from 1000 to 1600, did you tune your fuel map again?
Old Apr 24, 2005 | 10:37 AM
1sgen's Avatar
583 rwhp 1st gen
what you are saying that i have to take fuel of all the points that the sec. will be working in?
i thought the car will at least run my be mega rich but mine feels like it shuts down.
Old Apr 24, 2005 | 11:18 AM
Crusader_9x's Avatar
when i first changed over to big secondaries my car did the same thing. No matter what i tried nothing made a differnce. It turned out that i broke the connectors in the injector plug and had to buy new ones. Just a thought.
Old Apr 24, 2005 | 05:33 PM
FC_mania's Avatar
my situation is the same the car want to shut down because its mega rich , so i started to pull out more fuel and it pulls to 7k now no problem
Old Apr 24, 2005 | 06:19 PM
puntorotary's Avatar
Rotary Mechanic
Is you car streetported?
Old Apr 24, 2005 | 11:37 PM
1sgen's Avatar
583 rwhp 1st gen
yes street ported with t72
injection perfection IDA intake
hks exhaust manifold
Old Apr 24, 2005 | 11:43 PM
rxeng's Avatar
Set the staging to 99% (Please read the post I did which is a sticky at the top of the page on how staging works)
Set the Map stage to 4psi
Set the RPM stage to 3000
Don't try & tune the fuel out with the WOT maps.It won't work properly.You will need to go & do it from 4psi onwards in the load map.
When you have these injectors set up right you will see the fuel map curve upwards to around 6.00 M/S at 4psi & then drop down down to around 3.00 M/S at the 6Psi screen & then start to curve upwards again.
Try this & it will work
Old Apr 25, 2005 | 01:58 AM
Infini IV's Avatar
Microtech Tuning!
Think about it... you are putting injectors in that are nearly 2 times bigger than your original injectors. Even going from a 550/550 combo to 550/720 combo could bring a stumble, let alone going from 550/1000 to 550/1600 at the same staging point of 3000rpm.
Also, you may want to upgrade your primary injectors as well... A T72 flows a lot of air
Old Apr 26, 2005 | 11:24 PM
1sgen's Avatar
583 rwhp 1st gen
i will try that setup and if it works , i owe you lunch .
i will be in sydney in june, give me your address and i 'll swing by and bring you lunch :-)
Old Apr 27, 2005 | 11:36 PM
1sgen's Avatar
583 rwhp 1st gen
it did not work , i tried it and it still doing nearly the same thing . it feels like it runs on 1 cylinder and then when i back off it pops real loud from the back muffler.
help please :-)
Old May 1, 2005 | 04:39 PM
onefastrx7's Avatar
help please :-)
Check the continuity on the wires of the secondary injectors. Make sure they are coming online. Do you hear a lean or rich pop?
The Microtech should do its job with the settings that rxeng recommended.
Old May 1, 2005 | 10:34 PM
1sgen's Avatar
583 rwhp 1st gen
i'll make sure i'll do that
thanks for the advise
Shainiac
Jul 17, 2019 02:20 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
