Intercooler question.
Old Apr 19, 2005 | 09:13 AM
kevinbtz's Avatar
Shell 93
I was just wondering if any body has had a problem with radiant heat from the radiator heat soaking the intercooler. The reason why I am asking is because the spot I found for my front mount is 1 1/2 inches infront of the radiator, Thanks.
Old Apr 19, 2005 | 09:21 AM
rotoboy661's Avatar
dont worry about it man u gonna get heat soak anyways from your engine after its shu off
its fine, i had a fmic also and my temps lowered after i drove the car
no need to worry bro
Old Apr 19, 2005 | 09:31 AM
kevinbtz's Avatar
Shell 93
cool, just checking before I do the fab. work
Old Apr 19, 2005 | 12:34 PM
glemmers's Avatar
Polished aluminum has a low radiant absopriviity/emissivity. If you intercooler is "shiny", you won't pick up much radiant heat. If the intercooler is painted black, then radiation absoprption will be really bad.
Glenn
ls1swap
Jun 3, 2024 03:25 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
1NSIGHT
Sep 25, 2015 12:59 PM
