super fast irradic boost?
Old Dec 28, 2001 | 11:22 PM
slopoke's Avatar
well when i was driving to the local mexican joint tonight i noticed a strange, very slight vibration. when i looked at all my gauges i noticed that my boost gauge was acting strange. the needle was moving super fast back and forth but just a pound, from say 10-11 really fast. does this make sense, it was just realy jumpy when i gave it gas and it got into boost it would be realy shaky. has anyone ever heard of it doing this, any info will be greatly appreciated, thanks for all the help, scott
p.s. mods are intake,dp,highflowcat, cat back, ecu. thanks
Old Dec 29, 2001 | 12:10 PM
slopoke's Avatar
ok, today when i drove it i noticed that the BOV makes a real fast releasing of air. it is doing the same thing the gauge is doing just pulsating air out really quick, i have the stock BOV just unhooked from the intake so thats how i could hear it. it doesnt do it all the time either, just everyonce in a while. say i will be in 4th gear going 44mph and give it a little gas and *** it builds boost it jsut shakes back and forth very quickly. thanks for all the help, scott
Old Dec 29, 2001 | 01:27 PM
G 's 3rd gen's Avatar
Check the two hoses connected to the vacuum chamber. One might haved popped loose. If not it might be a different vacuum hose or a slight crack in one of your boost hoses.
Old Dec 29, 2001 | 02:15 PM
ErnieT's Avatar
Living life 9 seconds at a time
You more than likely have a boost leak. Either from a vacume line or intercooler connection.
Old Dec 29, 2001 | 08:41 PM
slopoke's Avatar
well after investigation, i could find no vacume lines off or any craked ones. i was wondering if maybe it could be my BOV not letting it hold pressure because if its doing it i can downshift and give it gas and it stops, like the valve released but when i gave it gas this time it closed, strange, i will keep checking for vacume leaks though, thanks for the help, scott
Old Dec 31, 2001 | 11:23 AM
slopoke's Avatar
i am still puzzled by this one, i also need to add that it started right after i put in the ecuu and intake. any ideas, thanks, scott
Old Jan 3, 2002 | 11:42 PM
slopoke's Avatar
well, i havnt solved this case yet, all the vacume lines seem to be fine. i believe it has to do with the waste gate control somehow, maybe it has gone bad or the solonoid is doing funny, any ideas? thanks, scott
Old Jan 4, 2002 | 12:42 AM
Red95T-Rex's Avatar
Rotard
check your vacuum solenoids, especially the throttle related solenoids....one of mine cracked and it had a similar effect. They are located right below the front part of the upper intake manifold. (Behind the alternator I think) hope that helps a lil. a new solenoid costs about 35 bucks and takes about 1 hour to install becuase u have to pull the alternator.
Old Jan 4, 2002 | 12:48 AM
slopoke's Avatar
thanks, could you visibly see the crack or did you have to check it somehow? thanks again, scott
Old Jan 4, 2002 | 01:16 PM
rx7eaven's Avatar
Scott, you been talking to yourself a lot lately haven't you? hehehe I hope mine does not start doing that when I get my intake on there. Let me know and I will help u look it over.
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
