Apex Twin Chamber Blow Off Valve.
Old Dec 28, 2001 | 03:35 PM
Question Apex Twin Chamber Blow Off Valve.
Anybody know what pressure the Apex blow off valve should open as I need to have it calibrated.
Please help !
Old Dec 28, 2001 | 03:52 PM
Any Info
Old Dec 28, 2001 | 04:06 PM
DomFD3S's Avatar
Mod Powers...gone!
You can call Apexi now as they are still open right now. Speak w/ one of their tech guys.
Old Dec 29, 2001 | 04:20 AM
i have a stock fd with downpipe and catback, my apexi bov setting was fine the way it came with...
i have the bov kit for FD tho...
Old Dec 30, 2001 | 03:52 AM
CantGoStraight's Avatar
What's your point ?
Blow off valve under pressure
I don't think the blow off valve should open under pressure.....am I wrong in thinking it opens under vacuum ?????
Old Dec 30, 2001 | 03:58 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Re: Blow off valve under pressure
you would be correct sir...
Old Dec 31, 2001 | 08:31 AM
OK, what vacuum should it open then ?
Old Jan 1, 2002 | 07:59 AM
Any answers, thanks for your help.
Old Jan 1, 2002 | 08:33 AM
kwikrx7's Avatar
I've only driven one FD with a BOV (aftermarket) and it opened up in vacuum (pretty loud too) but I'm not sure what vacuum reading it was. My stock BOV opens up as soon as I let off the gas at WOT to shift (it's pretty loud too)
Old Jan 1, 2002 | 09:05 AM
What's your point ?
Is it adjustable
The more vacuum the more it opens, if it's adjustable you should be able to set it from soft (opens farther with lower vacuum) to hard (takes higher vacuum to open it farther. I'm not sure if this is what your looking for but it's my understanding of how these work (could be all wet here) the jest of it is it opens with vacuum to allow the boost pressure to vent (the woosh you hear) between gears or letting off throttle at high rpm.:o
Old Jan 1, 2002 | 08:54 PM
Nike178's Avatar
Colin, do urself a favor. Sell the apexi bov cause its garbage. Try HKS or Greddy
Old Jan 2, 2002 | 02:32 PM
Thanks for all your help.
Old Jan 2, 2002 | 03:20 PM
kelrx7r1's Avatar
TNC
Talking
nike 178 is it really that bad?
i know i had it for my fc turboII and it did give
me problems.what problem has it given to the fd owners?
Old Jan 2, 2002 | 04:53 PM
Nike178's Avatar
Well, i had it on my supra and after that experience, i wouldnt dare put in on my fd. It just leaked alot and on top of that, it sounded like ****. It just didnt perform well at all. I really liked the hks ssqv. Great sound and never caused one problem to me. Try it out
Old Jan 2, 2002 | 05:17 PM
Chron's Avatar
Well, i had two HKS SS BOV on my TO4 turbo since one couldn't handle the pressure, so i dunno if i would go back to it.
