Sponsored by: CARiD
need to hit the gas a few times before starting on my 89 t2
Old Apr 13, 2005 | 02:12 AM
DriftingB26RX7's Avatar
Porsche-Hunter
Thumbs up need to hit the gas a few times before starting on my 89 t2
so this happens about 95% of the time, any one know what the problem is ??
Old Apr 13, 2005 | 06:58 PM
tidanb0utch's Avatar
when you crank,
hold the gaz pedal all the way down.
dont push it many time.
Old Apr 13, 2005 | 09:45 PM
R-apid-X-haust-7's Avatar
WHY NOT!!!
also if you hold ur car at 3k rpm and turn the key off while depressing on the pedal,(this is like when you come home and are geting out of your car)when you go to start it the next time it should start with the turn of the key. RX7s flood thats that, the more you press half throtle on that pedal the more flooded it gets.
(generally)
Old Apr 14, 2005 | 12:20 AM
Porsche-Hunter
well when i get in i put in the key and put the clutch all the waydown and then trun the key, then if it dosnt go i hit the gas like tap it or if it needs to goinn w.o.t but its mostely tapping
Old Apr 17, 2005 | 03:18 PM
Porsche-Hunter
bump^
Old Apr 18, 2005 | 02:13 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
it isn't getting enough fuel then.
when you stab the gas pedal quickly, the computer reads it and activates the "accelerator pump"...same thing as the pump on carburetors, just the computer does it with increased pulse width to the injectors.
make sure the fuel pump is getting enough voltage, change the fuel filter, clean the injectors, etc...
Old Apr 19, 2005 | 03:04 AM
Porsche-Hunter
word thankx
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
smikels
Aug 18, 2015 01:26 PM
