autometer boost gauge lights
Old Apr 8, 2005 | 07:40 AM
capn's Avatar
Mechanical Engineering
Hey all
i installed my autometer boost gauge last night and it works like a charm reads @5.5psi. but what i would like to know is what wires to splice, and or area to connect for the back light. i was thinking of putting it in parralle with one of the bulbs in the dash. but wasnt sure, what did you do?
Old Apr 8, 2005 | 07:54 AM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
i want to know too please help us out pm me when you get it capn
Old Apr 8, 2005 | 08:19 AM
KNONFS's Avatar
B O R I C U A
Originally Posted by capn
Hey all
I don't remember the colr of the wire, but thats exactly what I did. I actually traced one of the cables coming out of the lights switch, the one for the parking lights.
Old Apr 8, 2005 | 10:17 AM
cezonetheillest's Avatar
i thought that the parking light system was a red/black(stripe) wire. i thought that is what it was.
Old Apr 8, 2005 | 11:40 AM
ddub's Avatar
i am legendary
You could just run the backlight with power and have the light on all the time. I do this with my autometer z series lights (clear light didn't use the color things) and during the day it doesn't even look on.
Or you could use the cig lighter light power feed, that turns on when you turn the lights on. Or just get a multimeter and start testing wires with lights on/off to see which get power when you turn the lights on.
Old Apr 8, 2005 | 11:52 AM
capn's Avatar
i was thinkng like run it to the light for the rear heater light on the dash and make it in parallel because i dont want to be running wires all the way to the cigarette lighter
Old Apr 8, 2005 | 01:07 PM
KNONFS's Avatar
B O R I C U A
Tht will work too
Old Apr 8, 2005 | 01:12 PM
capn's Avatar
Originally Posted by KNONFS
Tht will work too
awesome i'll do a DIY on it
Old Apr 8, 2005 | 01:34 PM
Aaron Cake's Avatar
Engine, Not Motor
Personally, I like my gauges to dim with the rest of the lights on the dash.
Grab the trusty Haynes manual, and look in the wiring diagram for the wire colour that goes from the dimmer to the dash lights. Memory says it's red/green, but VERIFY THAT before you do anything.
Now, connect one side of your bulb to that wire, and the other side to ground. You can put about 4 extra bulbs on this circuit before you have to start worrying about overheating the switch.
Old Apr 8, 2005 | 02:16 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I just hooked up my illumination wire from the cig lighter bulb wire. It lets me dim my gauges and you dont have to search for the correct wire for the dimmer switch.
Old Apr 8, 2005 | 02:58 PM
gingenhagen's Avatar
I am 2Furious
yup, in parallel with the cig lighter bulb. Actually, i cut off the bulb, and have two gauges running in parallel off those wires.
Old Apr 8, 2005 | 03:35 PM
gerbraldy's Avatar
wtf's a piston
I have the autometer gauge, it works, don't know how accurate it is. I took the little red cap that came with it, put it on the bulb and it's pretty dam close to the stock gauge colors, almost looks stock. Mine isn't set to dim though, I'll have to do what Aaron cake said.
Old Apr 8, 2005 | 05:36 PM
capn's Avatar
i think its very accurate for what it is; stock S4 TII is only suppose to bosst up to 5.5 right? because it hits it almost exactly
also before i get everything set up i have to go and get more nylon tubing because its a bit of a strech for what came with the gauge. i'll also paint the tube black (the part that is in the engine bay) for a cleaner look.
Snoopy FD
Dec 8, 2015 01:45 PM
TerryD
Aug 23, 2015 07:40 AM
