1 Piston Caliper to 4 piston
Old Apr 8, 2005 | 02:37 AM
Tape.Worm's Avatar
a reliable rotary? STFU!
I just recently took off a set of these from my friends FC. I got the front one's and mounted them onto my FC and put my single piston one's on his. He just sold it so I happaned to be lucky that I got them off a day before the sold it. But the pedal now feels a bit more "mushy" not has firm as it used to feel. I was thinking maybe I should just get some steel line, or steel braided brake line to eliminate some of that "mush".....any suggestions or comments as to why it may be a little more mushy?
Old Apr 8, 2005 | 02:46 AM
introVert's Avatar
putting it down daily
This from Captain Obvious-
Did you bleed them properly? I would check that before you go slapping on stainless lines (not that that would be a bad idea anyhow...)
Other than that, I am not sure if there is a difference between master cylinders for the swap... someone with better knowledge can jump in here...
Old Apr 8, 2005 | 08:42 AM
ImprezedRS's Avatar
Damnit, steel doors hurt!
i put the four piston on my 90 gtu and it felt fine i would, i would flush and bleed the whole brake system, also would check for any leaks
Old Apr 8, 2005 | 10:04 AM
PoderRotativo's Avatar
I just did it to my SE and at the begining felt soft but now is normal but I think is better if you buy ss lines
Old Apr 8, 2005 | 04:56 PM
Tape.Worm's Avatar
Talking
Yeah bled all the way around. For some reason feels fine now. I think I'm still going to get the steel braided brake lines...There is some air craft place where I live and the guy will customize/size them to your liking....$10 a piece....which isn't bad.... But yeah thanks anyways....
Old Apr 8, 2005 | 04:58 PM
SAiamNE's Avatar
I always bleed once... then go back to the rear tire and bleed them all again a second time..
Pedel should feal as hard as a rock...
If you do have a VERY minor amount of air in the system it should eventually work it's way out..
Old Apr 8, 2005 | 05:34 PM
jgrewe's Avatar
GET OFF MY LAWN
Always good to give the calipers a few light wacks to help any air bubbles find their way to the top/bleeder.
GKW
Sep 28, 2015 04:34 PM
